Motor Bucking And Kicking Most At High Rpm - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by matt1969, this thread has received 3 replies and been viewed 759 times.
post #1 of 4 (permalink) Old 06-10-2007, 05:56 AM Thread Starter
I need some help with my truck.its a 2001 ram.im having a problem with it just running like crap for about a year.it sometimes runs alright and sometimes runs like crap.it pukes when i floor it from a stop and realy bucks at high rpm.latley if i park it on the incline of my house pad with the motor going up hill it has a hard time starting in the morning.i ran some some dirty fuel back when all this started. it always helped when i changed the fuel filter,but now it only helps a little .last time i had a good amount of fine silt like crap in the bottom of the filter housing.it helped out alot after changing the filter and cleaning all the carp out of the housing.so i dont know if i have a lot of crap in the tank or my lift pump or injector pump is going bad.any help would be great.
matt1969 is offline
post #2 of 4 (permalink) Old 06-10-2007, 02:15 PM
bmoeller's Avatar
Welcome to the TDG. :Thumbup:
Sounds like you need to drop the fuel tank and clean it out. Then see how it acts.
A fuel pressure gauge would a wise purchase. The fuel also lubes the fuel injection pump. No lube oil like the earlier fuel injection pumps.
"Obama = Hoax and Chains"
bmoeller is offline
post #3 of 4 (permalink) Old 06-10-2007, 06:12 PM
I agree, you may have run enough trash throught the VP44 that it cannot function properly. I would personally get the fuel pressure guage in case there is a chance of saving the VP44.
Stephen!
StrokeThisGoat is offline
post #4 of 4 (permalink) Old 06-10-2007, 10:10 PM Thread Starter
is it just as easy to make my own gauge set ,or just buy the kit for 50 bucks.and what are the pressures im looking for.if i have to drive for some of the checking do i just get a long enough hose to make in the cab or is there a kit with all the stuff i need.
thanks
matt
matt1969 is offline
