fuel system - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by redneckchief, this thread has received 14 replies and been viewed 1270 times.
post #1 of 15 (permalink) Old 06-11-2007, 02:26 PM Thread Starter
fuel system
ok guys i want to get a spare perf. lift pump and maybe an injection pump for my 02 what would give me the most bang for my buck i have 4'' banks exhaust pac brake and a afe cold air soon to come is 100 hp injectors and an edge juice w/tude
redneckchief is offline
post #2 of 15 (permalink) Old 06-12-2007, 02:51 AM Thread Starter
a little help would be much appriciated fellas what are some common set ups
post #3 of 15 (permalink) Old 06-12-2007, 02:52 AM
Cummins Man
Dazedandconfused's Avatar
I'm running the Wicked Diesel performer system and love it. Affordable and does a great job. Click the link in my sig and it will take you to the page.
Andy
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Dazedandconfused is offline
post #4 of 15 (permalink) Old 06-12-2007, 03:18 AM
tbroadus_41's Avatar
For that price you could buy a FASS
tbroadus_41 is offline
post #5 of 15 (permalink) Old 06-12-2007, 03:34 AM
haz-mat19's Avatar
I have a FASS and it has been awesome for 3 years now, 20 at idle and never below 16 at WOT.
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
haz-mat19 is offline
post #6 of 15 (permalink) Old 06-12-2007, 05:01 AM
I have the Eliminator from Wicked Diesels. I adjusted it to 15psi at idle. Its boost referenced so the more throttle you put down the more psi the pump kicks out. So far ive seen 40psi fuel at 30psi boost. Its a 200 gph pump capable of 70 psi and wont draw over 4 amps. FASS got nothing on it.
1911 Guy is offline
post #7 of 15 (permalink) Old 06-12-2007, 04:33 PM
fuel 40 psi i dont think thats to good
Josh
01 2500 dodge 24 valve 200k miles, striaght pipe exhaust, bully dog j-hook,home made cold air intake,Full Georend tranny,billet input,billet output,lam flex plate, TQ lock-up switch, Holley Blue pump, RV275's, BD top speed elimintator w/RAD Hot Edge juice w/Attitude
:smoke
masonjo is offline
post #8 of 15 (permalink) Old 06-12-2007, 04:45 PM
Dad
Isn't 20 max on the VP input side? Not below 10 PSI on the low side.
Dad is offline
post #9 of 15 (permalink) Old 06-12-2007, 04:51 PM
you can go up to 25 psi but i wouldnt go anymore idleing and 14 on wot and try to keep it above 10 all the time
Josh
:smoke
masonjo is offline
post #10 of 15 (permalink) Old 06-12-2007, 04:56 PM
Bouncer
25psi on a VP44 is way too much. You will bust the diaphragm with that kind of pressure. I would never run anymore than 16-18psi and try to keep it above 10psi all the time.
