Help!!!!!!!!!!!!!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by matt1969, this thread has received 3 replies and been viewed 469 times.
post #1 of 4 (permalink) Old 06-11-2007, 11:25 PM Thread Starter
Help!!!!!!!!!!!!!!!
Im working on my 2001 ram diesel for surge a problem.im looking at the lift pump first.i dont have my fuel pressure gauge yet but i wanted to get this repair going.first i pulled my filter to check for fuel flow from lift pump i turned key to the on position and got nothin .so i bumped it to the start pos .nothing .so did all kind of stuff with the key .notin.so pulled the plug and tried to do a volt check but its hard when your by yourself so i cant get a volt check now but i m sure i got power.so my question should there be fuel coming in to the filter housing when i cycle the key?also i started truck with the lift pump unplugged for a minute and ran just like it did with it plugged in.so im guessing the pump is bad.
any help would be GREAT.
THANKS
MATT
matt1969 is offline
post #2 of 4 (permalink) Old 06-12-2007, 12:15 AM
TDG Mafia Member #45
jarhead's Avatar
yeah i would say your lift pump is out. get ready to put a injection pump on.
Randy
05 Dodge str8 pipe, smarty jr, afe, airbags, and pacbrake.
jarhead is offline
post #3 of 4 (permalink) Old 06-12-2007, 01:40 AM Thread Starter
i think it has bin bad for awhile.is it a definite that inj pump is gonna die?
matt1969 is offline
post #4 of 4 (permalink) Old 06-12-2007, 01:51 AM
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
More than likely it is also bad, but you could get lucky. if you do have to replace it, I would go ahead and spend the extra money to get a hot rod pump. Just my :2cents
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
