Electric Fuel Pressure Gauge - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by matt1969, this thread has received 4 replies and been viewed 1729 times.
post #1 of 5 (permalink) Old 06-13-2007, 02:54 AM Thread Starter
i need some advice. i want to put in a fuel pressure gauge.i want to do electric so dont have to deal with the fuel line going to the gauge.any help would be great.where to buy and where to mount.also my oil pressure gauge went crazy one day and now just reads half way across the gauge Evan with the motor off.is this a bad sending unit or a computer problem I herd a computer flash sometimes fixes this.
thanks
matt1969 is offline
post #2 of 5 (permalink) Old 06-13-2007, 03:27 AM
matt, i just installed Autometers pro comp ultra lite fuel pressure gauge in my truck. It is an electrical gauge and is a VERY easy install. I bought mine from jegs for about 237 bucks. I have it mounted in my A pillar. Comes with light, sending unit and all other wiring.
Its their 0-30 PSI gauge. PM me for a link if needed
CumminsCrazed is offline
post #3 of 5 (permalink) Old 06-13-2007, 04:50 AM
What year is your truck. 02 could be an ECM issue, thats the year they went to fake oil press. gauges. Its probably a bad sending unit, or you gauge itself is shot. As for the Fuel press. You wouldn't run fuel directlt to the gauge unless mounted externally. You can run an isolator though which will let you run the gauge in the cab, and not pay the price of an electronic gauge. For mounting, is your truck an auto or a manual? The autos have a nice little cubby hole that you can put a block off plate and a gauge in, which still allows room for 3 other ones on the pillar. If you have a manual, you can mount all 3 on the pillar.
post #4 of 5 (permalink) Old 06-14-2007, 02:12 AM
2nd Gen Guru
Mopar1973Man's Avatar
I got mine for about $40 bucks but its not a electric gauge though...:Thumbup:
Mopar1973Man is offline
post #5 of 5 (permalink) Old 06-14-2007, 03:06 AM
Bouncer
I recently installed a new B&M Blackout series electric fuel pressure gauge. I got mine new from a store on Ebay for about $85. They have also recently been advertised in Diesel Power.
