Rough Idle or something Rattling bad - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by WBV06CTD, this thread has received 11 replies and been viewed 10665 times.
post #1 of 12 (permalink) Old 06-15-2007, 05:20 AM Thread Starter
When my truck is idling it sounds like something is wrong or rattling real bad.. But as soon as you touch the pedal it stops.. If you are in neautral it will have a lopy idle like something is grinding somewhere.. But when driving down the road nothing seems wrong.. My truck sounds like it has a double disk clutch on it and it is an automatic truck!! Need help on what this is
WBV06CTD is offline
post #2 of 12 (permalink) Old 06-15-2007, 10:23 AM Thread Starter
Almost sounds like it is coming from where the flex plate is.. could it be something in there. I am going to go get it checked out next week.. It sounds really bad though!
WBV06CTD is offline
post #3 of 12 (permalink) Old 06-15-2007, 10:42 AM
mrector's Avatar
If it does this while in N, then pull the little access plug and check your T/C bolts, before you do anything else--could be loose. It may be something else but I would go over everything I could on the bellhousing, flexplate, t/c, and anything else you can get your hands on in the drivetrain, just to check tightness/torque.
If you find that it isnt drivetrain then at least you'll know it'll be safe to drive without failure.......drivetrain wise.
Mikey
89 w250 project truck
mrector is offline
post #4 of 12 (permalink) Old 06-15-2007, 12:32 PM Thread Starter
yeah it has the loud rattling noise when I am neutral... I can stick in in Drive and when I start to move the noise quits but when the idle drops back down the noise starts again
WBV06CTD is offline
post #5 of 12 (permalink) Old 06-15-2007, 02:46 PM
Like mikey said, check your drivetrain and make sure there is nothing wrong there that way you at least know thats safe.
When did you put those Connector tubes in? Those will make a truck idle loppy and funny and sound a lot different. If you've had them in for a while and it just started making this noise then I don't know what to tell you. Let us know what you find out. and good luck.
post #6 of 12 (permalink) Old 06-16-2007, 05:11 AM Thread Starter
The connector tubes have been in there for a while almost a year.. and it has a lopy idle.. this noise sounds like something is broken.. and I am sure that it is the flex plate it has gotten really loud.. so I parked it for now and I am going to take it to my Cummins mechanic on Monday.. In the mean time I am driving a nice BMW z4 :
WBV06CTD is offline
post #7 of 12 (permalink) Old 06-16-2007, 06:33 AM
I had that problem a few months ago your about to loose all your tc bolts... so if it's bad enough your going to need a new flexplate and the tc will needs some attention too. if you need to go that far if the tranny is older might as well tear it down because it's pretty much out when your fix the flex plate and converter
01quadcab is offline
post #8 of 12 (permalink) Old 06-16-2007, 08:06 AM Thread Starter
yeah.. I got the flexplate just incase it might be cracked.. I just got the new transmission in about a month ago.. so I am hoping that nothing is wrong with that part.. Im hoping something is just loose and needs to be tightened back up
WBV06CTD is offline
post #9 of 12 (permalink) Old 06-16-2007, 11:38 AM
mrector's Avatar
You can check the t/c bolts in a matter of less than half an hour, I'd check em'.......mine were loose too, about a month after tranny install.
mrector is offline
post #10 of 12 (permalink) Old 06-18-2007, 12:42 AM Thread Starter
Well I checked up under my truck today and pulled the dust shield on the transmission and there was metal shavings on the lip.. I turned the motor over a couple of times and noticed that the flexplate was chipped and missing some pieces on it.. I went ahead and ordered my flexplate.. I hope nothing is wrong with the torque converter or transmission..I was able to drive it home.. not to far of a distance.. So I am hoping that the flexplate install will cure my issue
WBV06CTD is offline
