Semi wheels 22.5's - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blackpsd, this thread has received 6 replies and been viewed 1323 times.
post #1 of 7 (permalink) Old 06-16-2007, 08:14 PM Thread Starter
Semi wheels 22.5's
anyone running semi wheels? what are your thoughts on them? I want to run a set of Freightliner 22.5's on an 01 6spd 3500, simply for looks and tire life. I haul (heavy). And have asked a few people about them but never recieved any "real" answers. The truck is a 2wd, is lifting necessary? Someone fill me in
How would I be able to calibrate the speedo? etc etc
'01, DRW, Cummins HO, 6spd, hrvp44, holley black, fbd 150hp injectors, edge juice w/ attitude, 4" magnaflow exhaust, Bullseye Power s362 turbo, BHAF, Valair Clutch
blackpsd is offline
post #2 of 7 (permalink) Old 06-16-2007, 09:15 PM
I am not sure about the lift, but I do know that with 2.5" leveling spacers in the front end of mine, the 315-75-16 would rub the wheel well liner at full steer. As far as the speedo, you have to know the revolutions per mile for the tire being used. Take it to the **ealer, have them hook up and go into the ABS, and set the 'Ping rate' for the ABS gear to tire's rpm. My dealer said it would have cost me $25 to do it, but since I showed them how to do it, no charge.
03 3500HD 6x6 starting the add ons.
HAD'01 Ram 2500 SLT Laramie 4x1of2, 24v CTD, electric blue on silver 2-tone, matching blue spray-in bed liner, leveling spacers in front end, 3:55's, 'pork chop' tool boxes and tailgate box, back up/ work lights under rear bumper, On-board air, Roof mounted Air horns, Gauges in Pillar include Fuel PSI (pre & post filter), Oil PSI, Boost/EGT, Engine temp/Trans temp. BHAF, Edge EZ
Firestorm is offline
post #3 of 7 (permalink) Old 06-16-2007, 11:55 PM Thread Starter
the tire size I would need to run is a 255/70/22.5 I believe, I'm mainly curious if the truck will be "sluggish" after the swap
blackpsd is offline
post #4 of 7 (permalink) Old 06-17-2007, 12:27 AM
Mafia #42
HighTQCummins's Avatar
Location: Valley Forge PA/West Long Branch NJ (college)
Send a message via AIM to HighTQCummins
it may be because the tires raise the gear ratio, simply because the tires cover much more distance in one revolution compared to the old ones. for instance on the calculator on here i figured out a set of 255/70/22.5 w/ a rear end ratio of 3.55. At 3k rpm you would be going 91 something (Direct drive not O/D) then calculated that w/ the tires, in effect your rear ratio is now 2.18. So yes it would definately lower your gears making it slower off the line, but faster at top end.
Hank
TDG and the Mafia lives on
TDG B.O.M.B. Squad #5
My Truck:2007 Toyota Tacoma V6 4x4
Diesel is in my blood, I guess you can call it a disease, sadly there is no cure for it, it's my cross I must carry
HighTQCummins is offline
post #5 of 7 (permalink) Old 06-17-2007, 01:14 AM Thread Starter
hmmm I wonder how that would affect me with a 16k # trailer
blackpsd is offline
post #6 of 7 (permalink) Old 06-17-2007, 02:40 AM
Mafia #42
what is your rear end ratio out of curiosity??
Hank
post #7 of 7 (permalink) Old 06-17-2007, 02:40 PM Thread Starter
3.55's
blackpsd is offline
