silencer ring - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by oliver-2150, this thread has received 30 replies and been viewed 2945 times.
post #1 of 31 (permalink) Old 06-18-2007, 02:16 PM Thread Starter
silencer ring
hi guys, i just bought a 2000 3500 reg cab 4 wheel drive 5 speed saturday and was wondering if these have a silencer ring in the turbo. and if removed does it make a big difference in the sound, also i assume it is right in the front of the turbo in the intake side. what does it take to remove it? thanks alot. i like the doodge already and i have only had it 2 days!!:
2004 F-250 C.C. L.B. 6.0 6-speed, ISSPRO boost and EGT gauges, SCT by innovative diesel - 2000 Dodge 3500 Cummins 5-spd
oliver-2150 is offline
post #2 of 31 (permalink) Old 06-18-2007, 02:34 PM
redneckcummins's Avatar
It makes some difference in sound. to really hear put an aftermarket sir filter in there. Remove it youll will need a flathead screwdriver to get under the snap ring that holds it in place. takes about 5mins start to finish
FOR SALE 2003 3/4 ton goat, 6spd., 5in stacks, AFE stg 2 intake,
Isspro guages and Smarty
Wrecked 94' 12v. 2wd, regular cab auto.Isspro boost,pyro and trans temp. AFE intake. ground plate, .191DV's, 370's KDP ELIMINATED...... you will be forever missed.
redneckcummins is offline
post #3 of 31 (permalink) Old 06-18-2007, 09:49 PM
how do you do it i have never heard of this
bada$$dodge2000 is offline
post #4 of 31 (permalink) Old 06-18-2007, 10:57 PM
I did it to my truck you couldnt really tell a difference until I installed a BHAF.
But, you take off the intake tube and right in front of the turbo fan there is a little ring.
Grab a flathead screw driver and pop it off and install the intake tube back on and your ready to go.
199eightcummins is offline
post #5 of 31 (permalink) Old 06-19-2007, 03:11 PM
Bouncer
post #6 of 31 (permalink) Old 06-29-2007, 06:13 AM
Here are a couple of before and after shots ...
Attachment 11962
Attachment 11963
Name:	silencer ring removal 003 (2)RESIZE.jpg
ID:	10937   Click image for larger version
Name:	silencer ring removal 008 (2)RESIZE.jpg
Mayfair is offline
post #7 of 31 (permalink) Old 06-29-2007, 06:14 AM
It doesn't increase hp, get you better fuel mileage, or anything like that. ALL it does is make it sound AWESOME !! Change your intake and exhaust a bit and it'll REALLY scream !!
Mayfair is offline
post #8 of 31 (permalink) Old 06-29-2007, 09:35 AM
Makes girls think your truck is a "Spaceship"
Smokem is offline
post #9 of 31 (permalink) Old 06-29-2007, 01:02 PM
Mine came without one and I didn't really notice a difference until I put the BHAF on. Now it screams when you even get 5psi of boost and sound like a jet after about 15 or so
Silverline is offline
post #10 of 31 (permalink) Old 07-01-2007, 02:30 PM
I diid it to mine and I love the sound.
mopar98 is offline
