So is this what owning a Dodge is all about? Pix inside! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blackpsd, this thread has received 44 replies and been viewed 2332 times.
post #1 of 45 (permalink) Old 06-18-2007, 09:27 PM Thread Starter
So my second day driving this truck and had to get towed in by a trusty ol' Ford. This is not making a Ford guy feel welcome to the Dodge world. Symptoms; the truck just shuts off in the middle of the damn road, multiple times while driving. Then takes forever to start back up, it did it twice yesterday at totally separate times. But today I HAD to drive this truck because I sold the Ford here locally, well it shut off about 5 times and took a while to crank. Not sure what the deal is. any input?
'01, DRW, Cummins HO, 6spd, hrvp44, holley black, fbd 150hp injectors, edge juice w/ attitude, 4" magnaflow exhaust, Bullseye Power s362 turbo, BHAF, Valair Clutch
blackpsd is offline
post #2 of 45 (permalink) Old 06-18-2007, 09:38 PM
your fuel pump maybe? the vp 44 pumps are not that great. it kinda sounds like it will pump for a while then it wont. when you turn the truck on to wait for the wait to start light goes off can you here it prime its self?? if not it might be your lifter pump.
bada$$dodge2000 is offline
post #3 of 45 (permalink) Old 06-18-2007, 09:41 PM
Thats just bad luck. you could have bought a ford and had a problem as well.
Cold fodged is offline
post #4 of 45 (permalink) Old 06-18-2007, 11:05 PM
my neighbor bought a 2002(i think) ford f-350 power stroke and the same thing happened to him and he had to change his fuel filter and air filter and he said he hasnt had a problem with it sense he has done that.
just my 2 cents
199eightcummins is offline
post #5 of 45 (permalink) Old 06-18-2007, 11:35 PM Thread Starter
Its not the fuel filter nor the air filter, I took the air inlet pipe off of the turbo just now and it still will not start, I can't get it to start now, I started it revved it twice, it shut off, and will not start, the pump is kicking on and filling the fuel bowl, there is pressurized fuel coming out of the schrader valve, scanned it for codes, and it came back with no codes at all.
blackpsd is offline
post #6 of 45 (permalink) Old 06-19-2007, 12:01 AM
tbroadus_41's Avatar
Even though it's not throwing codes it could still be your injection pump. These are some of the main symtoms of this problem.
tbroadus_41 is offline
post #7 of 45 (permalink) Old 06-19-2007, 12:19 AM Thread Starter
even if it has pressurized fuel @ the schrader valve?
blackpsd is offline
post #8 of 45 (permalink) Old 06-19-2007, 12:33 AM
haz-mat19's Avatar
What kind of pressure, do you have a gauge. Your lift pump could be bad, and if it is and you keep running it the VP is soon to follow.
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
haz-mat19 is offline
post #9 of 45 (permalink) Old 06-19-2007, 01:20 AM Thread Starter
not sure, because it's not starting anymore :shrug:
blackpsd is offline
post #10 of 45 (permalink) Old 06-19-2007, 01:33 AM
well
It sounds like a bad lift pump. Same thing happened to me when my pump went out. Also make sure there is no debris blocking any of the lines.
veritas42 is offline
