2001 engine parts - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by jmul, this thread has received 4 replies and been viewed 557 times.
post #1 of 5 (permalink) Old 06-19-2007, 12:45 AM Thread Starter
2001 engine parts
i have a 2001 dodge 3500, 13100 miles. the rings are shot, but there is no wear on the piston walls. where can i buy new pistons, rings, oil pump, head bolts, rod bearings online, the dealer here wants 250 bucks for each piston. thanks for any help.
jmul is offline
post #2 of 5 (permalink) Old 06-19-2007, 03:04 PM
Bouncer
Go to Cummins and get your parts if you want the best. Although there is some nice aftermarket pieces out there as well available from various retailers.
I got to ask though, how is all that wore out with 13,100 miles? Even if that was a typo and should be 131,000 miles I still can not see how that motor is shot unless it naver had an oil change.
post #3 of 5 (permalink) Old 06-20-2007, 12:46 PM Thread Starter
yep, its 131,000 miles. i bought it from a used lot knowing it was blowing oil. got it for 5-K he orig wanted 9-K. the hose from the air filter to the turbo was very very loose and had been sucking in dust. thanks,
jmul is offline
post #4 of 5 (permalink) Old 06-20-2007, 01:29 PM
Bouncer
That dirt and dust will do it everytime.
post #5 of 5 (permalink) Old 06-30-2007, 02:49 AM Thread Starter
Found everything at diesel specialist in baton rouge, la. pistons, rings, piston pins, mains, upper and lower gasket set, thermstate, rod bearings, oil pump, & head bolts. all cummin's parts for my engine.2300 bucks including tax.
a little more than half of what the dodge dealer wanted for everything.
jmul is offline
