NV5600 Oil. - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Smokem, this thread has received 11 replies and been viewed 7791 times.
post #1 of 12 (permalink) Old 06-19-2007, 02:11 AM Thread Starter
NV5600 Oil.
The NV5600 which is the 6sp they put behind the HO Cummins I believe. Just wondering what kind of Oil type you're suppose to use. Curoius that's all, I don't have one or anything. But there is one for sale locally.
Smokem is offline
post #2 of 12 (permalink) Old 06-19-2007, 10:16 AM
I don't remember the oil rating, maybe GL-5 or somthing, but i remember that it was $26 a quart for penzoil for the last truck i worked on with the NV5600.
Stephen
StrokeThisGoat is offline
post #3 of 12 (permalink) Old 06-19-2007, 02:49 PM
Bouncer
I know in the NV4500 you must use a GL-4 rated oil because of synchro breakdown. I believe in the NV5600 you are allowed to use a GL-5 rated oil which is easy to find. The GL-4 is not available on the shelf and generally has to be ordered. Get with SoGrand, he can tell you for sure which one to use. I run Royal Purple in my 4500 which is a GL-4/GL-5 rated oil.
post #4 of 12 (permalink) Old 06-20-2007, 02:30 AM
any GL-4 if you go to dodge they will give you nv3500 fluid if you can find it try BG 792 SYNCHRO SHIFT
blowsmoke is offline
post #5 of 12 (permalink) Old 06-20-2007, 03:28 AM
lbdodge24v's Avatar
Not trying to jump in and take over on this post or change the subject, but how often should the oil in a manual trans be changed?? just wondering!!!
02 Dodge Ram CTD, 6 spd., HMR Street Drag Clutch, Raptor 150, Edge Drag Comp, Smarty, Injectors, aFe air intake, 2 in leveling kit, 4 in exhaust, and 3 guages-Fuel Pressure, Boost, and EGT's.
The Toy a Jummins!!
lbdodge24v is offline
post #6 of 12 (permalink) Old 06-20-2007, 03:41 AM
Images: 9
The oil we sell and recomend is Castrol Syntec. I have it in bulk and can sell it for 11.00 a quart. I recomend changing fluid around 25,000 miles if you are towing over the road every day and heavy. If not then around 40,000. I have some stuff coming down the line that Bill knows about and will share it with you guys when i get it. I hope the begining of August i will be able to share it with you.
Dan
SoGrand is offline
post #7 of 12 (permalink) Old 06-21-2007, 12:03 AM Thread Starter
So there isn't even a certain weight? like 80w90 or 75w140????
Smokem is offline
post #8 of 12 (permalink) Old 06-21-2007, 01:28 AM
ATS says to put BG 792 Syncro Shift II in the NV 5600
post #9 of 12 (permalink) Old 06-21-2007, 07:27 PM
I seem to remember someone saying that the NV5600 needed to be overfilled? Anyone know abou this?
nplake is offline
post #10 of 12 (permalink) Old 06-22-2007, 01:45 PM
it says to put 4.5 quarts in i always put 5 in throw the tower
