holley blue pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by redneckchief, this thread has received 27 replies and been viewed 1602 times.
post #1 of 28 (permalink) Old 06-20-2007, 02:39 PM Thread Starter
holley blue pump
so if i ran a holley blue pump along with my factory L/p what would happen if and when my oem L/p wore out?
redneckchief is offline
post #2 of 28 (permalink) Old 06-20-2007, 04:55 PM
ur pressure will drop a little bit more than the holley blue alone. cuz it will restrict the fuel. my truck was running 25 psi with stock anbd holley blue when my oem went out it went to 9 psi
Josh
01 2500 dodge 24 valve 200k miles, striaght pipe exhaust, bully dog j-hook,home made cold air intake,Full Georend tranny,billet input,billet output,lam flex plate, TQ lock-up switch, Holley Blue pump, RV275's, BD top speed elimintator w/RAD Hot Edge juice w/Attitude
:smoke
masonjo is offline
post #3 of 28 (permalink) Old 06-22-2007, 02:39 PM Thread Starter
so is this blue pump holley p/n 12-802-1 the street/strip gasoline pump?
and does it work well with diesel?
post #4 of 28 (permalink) Old 06-22-2007, 02:50 PM
Banned
Send a message via AIM to lukesdiesel
Ive been running mine now for several months with no problems.... I am running just the Holley Pump.... I would like to see more pressure though...
9psi @ idle
lukesdiesel is offline
post #5 of 28 (permalink) Old 06-22-2007, 04:45 PM
Boost Junkie
The holley blue pump is a great upgrade for our 98-02 trucks. Along with the Vulcan Big Line Kit makes it a great combo together.
And yes it is the p/n 12-802-1
Josh
91rangerturbo is offline
post #6 of 28 (permalink) Old 06-22-2007, 10:08 PM
02sprtcumns's Avatar
I thought the holley blue pump would have high fuel psi than that. I just bought one today it looks like my gov't issued cummins pump is craping out on me ill probably try to run both till that one dies all the way
02sprtcumns is offline
post #7 of 28 (permalink) Old 06-22-2007, 10:43 PM
9psi @ idle
ive ben running a blue for a while now with a big line kit. what you should do is stretch the spring in the pump...theres a plug on the side of the pump with the spring that controls the pressure. pull it and stretch it about a half inch longer. im running 16 psi idle and 12-14 wot
My_oilburner is offline
post #8 of 28 (permalink) Old 06-23-2007, 12:19 AM
Ok
So with the Holley blue pump it is best to use the vulcan big line kit? Also from my understanding the vulcan kit completely replace's the stock fuel line?
Also what is the best place to buy the holley pump from. Any suggestions appreciated. The holley blue pump I found online said for gas does it always say that? And as far as installation how long does it take to put on the vulcan kit and holley pump?
veritas42 is offline
post #9 of 28 (permalink) Old 06-23-2007, 12:25 AM
Advance Auto sells the Holley Blue pumps for $116 (I think that's the price here) I bought one a while ago for my mustang
'01, DRW, Cummins HO, 6spd, hrvp44, holley black, fbd 150hp injectors, edge juice w/ attitude, 4" magnaflow exhaust, Bullseye Power s362 turbo, BHAF, Valair Clutch
blackpsd is offline
post #10 of 28 (permalink) Old 06-23-2007, 12:28 AM
hmm
So the pump is multi-fuel, ok thanks man
