In tank LP vs. block mounted LP? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by mac325, this thread has received 10 replies and been viewed 1020 times.
post #1 of 11 (permalink) Old 06-20-2007, 11:23 PM Thread Starter
Question In tank LP vs. block mounted LP?
Are the new in tank LP's better than the old block mounted ones? I just put a new IP and LP on my truck 2 weeks ago. Now the sending unit in the tank is leaking fuel from the top fittings. My local mechanic called Dodge and said the only way to get a new sending unit is to buy the new one with the tank mounted LP, ahhhh. My mechanic said he can take it a part and maybe fix the old one, but he is not sure. But I guess if the in-tank LP is more reliable, I should probably just go with it. Let me know what you guys think.
:shrug:
Thanks,
Mac
mac325 is offline
post #2 of 11 (permalink) Old 06-20-2007, 11:30 PM
Diesel Mafia #67
blackcloudCTD95's Avatar
I herd they were better.. Or so my cousin said.. Altho he said running the FASS was the best investment he's ever made..!
Jordan
blackcloudCTD95 is offline
post #3 of 11 (permalink) Old 06-20-2007, 11:38 PM
both of the stock lift pumps are trash go with fass or another aftermarket pump
blowsmoke is offline
post #4 of 11 (permalink) Old 06-29-2007, 06:09 AM
I'd rather mount the fuel tank on my roof and let it gravity feed before I put an in tank fuel pump in !!
FASS baby !!
Mayfair is offline
post #5 of 11 (permalink) Old 06-29-2007, 09:28 AM
Yeap, FASS is the way to go even though I've heard of a few going out. It's still where I'd put my money at.
Smokem is offline
post #6 of 11 (permalink) Old 06-29-2007, 11:55 AM
Boost Junkie
Hmm.. That's another reason why i am choosing the holley/carter pusher pump route. It's cheap to replace if one does go out.
Josh
91rangerturbo is offline
post #7 of 11 (permalink) Old 06-29-2007, 08:21 PM
sure it fast and cheap to fix. but I'd rather not risk taking out the injector pumpp.
Silverline is offline
post #8 of 11 (permalink) Old 06-30-2007, 04:37 PM
tbroadus_41's Avatar
Just remember if you put one in the tank it will never go bad when the tank is empty. Putting an external pump on will be much easier to deal with than an in tank unit.
tbroadus_41 is offline
post #9 of 11 (permalink) Old 07-02-2007, 08:54 PM
FASS get's my vote.
mopar98 is offline
post #10 of 11 (permalink) Old 07-03-2007, 04:55 AM
What did you decide to do ??
Mayfair is offline
