A few Q's - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by tbroadus_41, this thread has received 3 replies and been viewed 605 times.
post #1 of 4 (permalink) Old 06-21-2007, 03:39 AM Thread Starter
tbroadus_41's Avatar
A few Q's
Ok so i'm going to buy injectors and a clutch in the near future like within a month, i'm not sure yet on how big the injectors are going to be but my question is.
#1 How big can i go keeping my box on a lower setting and not upgrade the turbo for a little while?
#2 I'm going to go with a southbend but which one? Where is my HP now and where might it be w/injectors. Do i want to get the Con FE?
# Besides a turbo what else should I beef up to try and prevent breakage? i.e head studs, o-rings, manifold and so on?
tbroadus_41 is offline
post #2 of 4 (permalink) Old 06-21-2007, 04:20 AM
What are you going to be using the truck for? Thats a big one. If you go easy and plan on upgrading the turbo later, you can run a pretty big injector for a while if you want.
post #3 of 4 (permalink) Old 06-21-2007, 05:24 AM
Well, it all depends on what you are going to do with the truck.. Seems like everytime you upgrade one thing sooner or later you are going to have to upgrade something else because one part seems to over power the other one.. I personally just shattered my flexplate for doing 20lb boosted launches at the drag strip!!! :shrug: But with just injectors and a clutch you should be fine for a while on the turbo.. I ran edge 150s and a hx35 and a built tranny for a while... yes it will get hot but you will be fine until you are able to upgrade.. If you want all out power, get their double disk clutch along with a drag comp and some EDM injectors.. That is the route I would go if you were truck pulling..!!
WBV06CTD is offline
post #4 of 4 (permalink) Old 06-21-2007, 12:48 PM Thread Starter
I thnk i want to get injectors around the 150 HP range and stay with the single disc for daily drivability. the truck is used for daily driving but does see some trailer time as well.
