rotor replacement - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Fanatic, this thread has received 5 replies and been viewed 564 times.
post #1 of 6 (permalink) Old 06-27-2007, 10:58 PM Thread Starter
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
rotor replacement
OK, Maybe I'm stupid, but maybe not, I have never done this on a dodge before. Got the spindle nut off, but can't get the stupid rotor off the truck, what am I missing, or am I just a sissylaugh I just don't want to break anything, or ruin anything. Who can help?
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
post #2 of 6 (permalink) Old 06-28-2007, 01:21 AM
I made a puller for mine out of an old rim center and some allthread for my 98 3500 maybe thats all you need
blowsmoke is offline
post #3 of 6 (permalink) Old 06-28-2007, 01:28 AM Thread Starter
TDG Mafia 36
Well, I also found out that you have to take the back 4 bolts off to get them off alsolaugh so now I got those off, so I am going to get a puller from work to get them off.
post #4 of 6 (permalink) Old 06-28-2007, 02:51 AM
lbdodge24v's Avatar
I am working on getting mine apart in the same place I think, the bearing and hub won't come off mine, I have a big three leg puller on it now, pulled it hard as we cold with a pull handle and the thing will not move at all!?! Any suggestions on this, I guess we are going to build something tomorrow to try and pull this with!!! I will go with any info given on this one also!!! I don't wanna break any more stuff than I have too. But i did get those four bolts out of the back!!!
well any suggestions, stupid bearing and hug would be stuck!
02 Dodge Ram CTD, 6 spd., HMR Street Drag Clutch, Raptor 150, Edge Drag Comp, Smarty, Injectors, aFe air intake, 2 in leveling kit, 4 in exhaust, and 3 guages-Fuel Pressure, Boost, and EGT's.
The Toy a Jummins!!
lbdodge24v is offline
post #5 of 6 (permalink) Old 06-28-2007, 03:21 AM
Bouncer
Heat and penetraing oil will be your best friends here. Along with the BFH you can fit in there to swing.
post #6 of 6 (permalink) Old 06-28-2007, 04:52 AM
Exactly what bouncer said. I use an Oxy propane or Oxy Acetylene torch to supply the heat. Works for any thing you have to get serious about.
