Idle Times - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Okie2500, this thread has received 7 replies and been viewed 637 times.
post #1 of 8 (permalink) Old 06-28-2007, 08:10 PM Thread Starter
Idle Times
i hear it is bad fr our trucks to idle for too long, but how long is too long?
i know if left too long then it will mushroom a piston correct? well im just curious what is the max i should let my truck idle, as i stop and go alot in the construction business
Okie2500 is offline
post #2 of 8 (permalink) Old 06-28-2007, 08:15 PM
tbroadus_41's Avatar
With your attitude you can look at you egt's. i shut mine down at 300 degrees bucause i hate walking away from my truck with just the park brake on when my turbo timer was on. At start-up in the winter i usually go about 5-10 minutes and in the summer 30 seconds after oil pressure builds.
tbroadus_41 is offline
post #3 of 8 (permalink) Old 06-28-2007, 10:50 PM
I don't know if your pistons will mushroom. But the top of your piston gets too cool, your piston rings shrink up and allow blow-by. The oil pressure gets to low so your piston sprayiers don't spray high enough in most cases, and your turbo doesn't see enough oil pressure and bad things can happen to it as well. What's an ok idle probably depends alot on the engine too, I've heard from several good sources 15 minutes is about too long. Which is my rule of thumb, however I know many other people that let there trucks idle hours at a time and still are fine. I really think it depends alot on your rig.
Smokem is offline
post #4 of 8 (permalink) Old 06-28-2007, 10:59 PM Thread Starter
i see. thanks guys. yeah i always use my attitude. shuts down at 290. i love the questions from friends and even randoms, "you know your truck just died right?" and the reply "oh my god holy sh*t! the attitude worked!" ha.
Okie2500 is offline
post #5 of 8 (permalink) Old 07-04-2007, 04:13 AM
My understanding is that the 24v heads water passages are so efficent that in COLD weather long term idling will cool the valve guides down so cold they will constrict to the point of seizing the valve. Depending in what position this happens in then yes most likely they will hit the piston. I belive unless you are in winter in cold climates the most you will do is foul your injectors with carbon deposits.
MRose is offline
post #6 of 8 (permalink) Old 07-04-2007, 02:59 PM
I guess that's why the truck won't warm up in the winter no matter how long it idles huh ?
Mayfair is offline
post #7 of 8 (permalink) Old 07-04-2007, 04:28 PM
I thought the mushrooming problem was only in the new 6.7. Thats why so many engines were getting replaced. I'll let mine idle for a long time but its only occasionaly and I havent had any problems.
JayRock is offline
post #8 of 8 (permalink) Old 07-04-2007, 04:54 PM
I try not to let mine idle for longer then 10min at a time. Sometimes I forget I left it runnin and it'll sit runnin for 45+min.
jakebrake is offline
