problems problems problems - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by blackpsd, this thread has received 22 replies and been viewed 1289 times.
post #1 of 23 (permalink) Old 06-29-2007, 04:16 PM Thread Starter
well maybe not that big of a problem, I hooked everything up to run a holley blue I had, and went to kick the ignition over, and nothing, no pumps at all running, I double checked all of my wiring and relay to make sure it was right and it was. Tried again, and nothing. I put a test light on the lift pump connector and it has no power at all, therefore I have nothing to signal my holley blue on/off. Any ideas?
Does anyone know what fuse is for the LP? I googled and it turned up with nothing. Thanks
'01, DRW, Cummins HO, 6spd, hrvp44, holley black, fbd 150hp injectors, edge juice w/ attitude, 4" magnaflow exhaust, Bullseye Power s362 turbo, BHAF, Valair Clutch
blackpsd is offline
post #2 of 23 (permalink) Old 06-29-2007, 04:22 PM
Boost Junkie
Check on the inside of your fuse panel. It should list what goes where.
Josh
91rangerturbo is offline
post #3 of 23 (permalink) Old 06-29-2007, 04:56 PM Thread Starter
I did that, just after I posted, switched out that relay and still nothing.
blackpsd is offline
post #4 of 23 (permalink) Old 06-29-2007, 05:22 PM
Boost Junkie
I would follow the lift pump wiring as far as i could with a test light or multi-meter and check for a break in the wiring.
Josh
post #5 of 23 (permalink) Old 06-29-2007, 05:26 PM Thread Starter
did that aleady, I checked continuity from as far as I could to the connector
blackpsd is offline
post #6 of 23 (permalink) Old 06-29-2007, 05:42 PM
Why is there 2 different spots on the ECM for Transfer Pump power?
Smokem is offline
post #7 of 23 (permalink) Old 06-29-2007, 06:22 PM
Possibly a ground issue?
Slated4Greatness is offline
post #8 of 23 (permalink) Old 06-29-2007, 07:03 PM
If it's coming out of the ECM doesn't that mean the Pump only running 5v source? I'm alittle lost lookin at this wire diagram. Haven't slept much last week, sorry if I'm looking over something easy. But my fuel pump hasn't worked for the last 20,000 Miles and I think I should try to fix it.
Smokem is offline
post #9 of 23 (permalink) Old 06-29-2007, 08:41 PM Thread Starter
there is no power at all coming from the + side of the connector, you need power + ground to make it work, it just has no power at all
blackpsd is offline
post #10 of 23 (permalink) Old 06-29-2007, 10:31 PM
are you using a known good ground to check your B+? Did the pin back out.
JayRock is offline
