Not pleased with mpg!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Canyon JYD, this thread has received 76 replies and been viewed 3011 times.
post #1 of 77 (permalink) Old 07-04-2007, 05:10 AM Thread Starter
Formerly NATTYGASMECH
Canyon JYD's Avatar
Angry Not pleased with mpg!!
I'm not too pleased with the mpg on my truck. I have not gone on a long trip yet. I do live 90 miles from nearest large city. When I fill up I'm full for 2 days. Is it possible short trips are to blame? I have only filled up at 3/4 twice, when I return to town. My numbers say 15.5 mpg. I notice you guys are advertising larger numbers than this. My truck is supposed to be stock. Last night a fellow who has been running dodge for a long time noticed something that I noticed as well, but thought it normal. When I fire up black smoke. When I get on it black smoke. I wrote it off to having straight pipe. Everything appears normal under the hood and even under the dash. He went right to checking things out. Is there a possible program in my computer? How can I tell? Also can a program reduce my mileage? If so any advice to remedy this situation would be GREATLY appreciated. I am interested in daily driving and long term dependability. As with any vehicle the most mph is the goal for economical reasons. I have looked into some programmers and they have different modes, fuel economy, towing, power. Does anyone know of a program that is put directly into the ECM? This is my first diesel, this is why I ask these questions. I am actually a mechanic by profession, just not on diesel.
Canyon JYD is offline
post #2 of 77 (permalink) Old 07-04-2007, 05:16 AM
I see 15.8 on my 55 mile round trip to work and back. That's half town and half freeway. I put an edge comp on mine thinking I would see a little better mileage but come to find out since the edge, I like to mash the skinny pedal more often. Still getting 15.7 but due to driver habits. I think I would see about 17 if I could keep off the throttle.
jakebrake is offline
post #3 of 77 (permalink) Old 07-04-2007, 05:21 AM
Official TDG Doctor
hccumminssmoke's Avatar
i have always blown smoke on start up and a very light haze when i matted on it...when was your last oil change? what kinda shape are your injectors in? what about fuel lines? air filter? I got 16.5 around town, now i get 19 around town w/ the Max Micro, and i went 400 miles interstate got 23!!!!! that was completly stock.
Nathaniel
hccumminssmoke is offline
post #4 of 77 (permalink) Old 07-04-2007, 05:23 AM Thread Starter
Canyon JYD's Avatar
The pedal is what I thought about thie first caculation. The next tank I actually babied it to see if there would be a difference. Though when I pass slow @$$*s I :grd . But that shouldn't account for that much. Thanks for the feed back. I don't feel so bad now. Kind of thought I was getting poor mileage. I would like to know if this is normal.
post #5 of 77 (permalink) Old 07-04-2007, 05:27 AM
What tires/size's? I'm getting about 20 on long freeway trips. Corse I haven't recalibrated for the larger tires yet.
post #6 of 77 (permalink) Old 07-04-2007, 05:28 AM Thread Starter
Canyon JYD's Avatar
I should add that I drive about 5 miles 2-4 times a day at 15-35 mph. on roads that passing is not an option. I can only pass when going to town.
post #7 of 77 (permalink) Old 07-04-2007, 05:31 AM Thread Starter
Canyon JYD's Avatar
235/85/16. 4x4 dually 5 speed, keeping the rpm b/t 12-2200.
post #8 of 77 (permalink) Old 07-04-2007, 05:49 AM
Yeah, I was going to ask about trans, tires and miles on the clock. It really comes down to driver. Also, I would go ahead and change all your fluids and especially your fuel and air filters. Those things being dirty will suck milage way down.
I usually get 16.5-18 around town, and 18-20 highway. both of those used to be around 2 mpg higher, but I think a slipping trans and shot converter are to blame for that.
post #9 of 77 (permalink) Old 07-04-2007, 06:02 AM Thread Starter
Canyon JYD's Avatar
The air filter is new and the oil is due in about 400 miles I'm told when bought. About 194 on the clock. Very well maintained truck. Don't know about the fuel filter. As to the light haze, compared to what I see some doing yes light describes it. But when you haze on each gear and leave a cloud on accelerating after a turn with moderate pedal that stays until you get 500-600 yds. down the road when the speed limit is 35 and don't exceed it, I question it now.
post #10 of 77 (permalink) Old 07-04-2007, 07:41 AM
Yeah, that sounds like a box, programmer, or injectors. Something of that nature. Usually those mods do alright for increasing milage though, depending on what it is. Most Boxes and programmers change Parameters such as timing to help with power and throttle response and they also help out fuel economy. Injectors, it depends on the injectors, some help milage because of improved spray patterns, and others hurt it, because they just hone out the stock holes, making them bigger and lowering injection pressure.
Its hard to say what your truck has done to it, but it shouldn't put out much noticable smoke if its stock.
However, your altitude could have a bit of an effect on things too. I see your from the Grand Canyon area. I was down in Flagstaff a little over a year ago, and my truck smoked quite a bit down there, and it doesn't have that much done to it. Also, EGT's can get dangerously hot, real easy at altitude, I could peg 1800* no problem. I'm not sure how high you guys are, but I would look into getting a pyro ASAP, especially if your truck is smoking, you could be running really hot.
