What chip works best with my truck? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Z_rock, this thread has received 23 replies and been viewed 1288 times.
post #1 of 24 (permalink) Old 07-05-2007, 07:26 PM Thread Starter
I have an 02 5.9L 3/4 ton completely stock (for now).
I'm looking for a chip that will create alot of horsepower.
what chip would you prefer and why?
Z_rock is offline
post #2 of 24 (permalink) Old 07-05-2007, 07:49 PM
I would say go with edge juice with attitude then you will have guages and all in one package especially because it has the fuel pressure guage cuz thats a major problem..you can always stack the edge with a smarty so I have heard. but you will want a cold air intake and a good exhaust on it for sure
01quadcab is offline
post #3 of 24 (permalink) Old 07-05-2007, 08:16 PM
diesel_ram_man's Avatar
Images: 6
:iagree just be aware your trans won't like you to much on the higher levels of the box.
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #4 of 24 (permalink) Old 07-05-2007, 08:58 PM Thread Starter
By stacking chips, won't I be changing my fuel timeing to much?
Z_rock is offline
post #5 of 24 (permalink) Old 07-05-2007, 09:05 PM
no your stack would need to have a fuel only box ex. smarty. one timing+fueling box and one fueling box
Josh
01 2500 dodge 24 valve 200k miles, striaght pipe exhaust, bully dog j-hook,home made cold air intake,Full Georend tranny,billet input,billet output,lam flex plate, TQ lock-up switch, Holley Blue pump, RV275's, BD top speed elimintator w/RAD Hot Edge juice w/Attitude
:smoke
masonjo is offline
post #6 of 24 (permalink) Old 07-05-2007, 09:17 PM
Images: 6
The Smarty has levels with out added timing and levels with added timing. You just make sure you keep the Smarty on the levels without timing.
Can You Keep Up??
post #7 of 24 (permalink) Old 07-05-2007, 09:27 PM
DPDIESEL's Avatar
Juice With Attitude is the way to go right now. There should be a new chip in the mix here shortly though.
Performance Diesel Motorsports
5,500 RPM Common Rail Anyone??
DPDIESEL is offline
post #8 of 24 (permalink) Old 07-05-2007, 09:39 PM
I agree that the edge juice/attitude combo is the way to go. I just got a new one on mine with new software cause it wouldnt let my truck shut off and i am very happy with the update. It seems they have moved the power curve around a little bit. Atleast according to my butt dyno.
JayRock is offline
post #9 of 24 (permalink) Old 07-05-2007, 10:19 PM
tbroadus_41's Avatar
DPDIESEL, what is this new box you speak of?
tbroadus_41 is offline
post #10 of 24 (permalink) Old 07-05-2007, 10:21 PM
Images: 6
: I'd like to hear about this also.
Can You Keep Up??
