cooling - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01quadcab, this thread has received 12 replies and been viewed 1640 times.
post #1 of 13 (permalink) Old 07-08-2007, 07:15 PM Thread Starter
cooling
ok first long uphill towing a load in my 01 and today it got a lilttle warm on the way up the hill not about the last white line and not to the 240 mark and the trans stayed below 195 but when it started to heat up my egts went up so I backed outta it is there a electric fan setup or something that can be done?
01quadcab is offline
post #2 of 13 (permalink) Old 07-08-2007, 11:43 PM
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
If I was you, first I would look in between the intercooler, and radiator to see how dirty it is, I had the same problem, and the front of my radiator was filthy. I pulled the intercooler off, and then the radiator, and cleaned everything. I haven't had the problem since.
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
post #3 of 13 (permalink) Old 07-09-2007, 01:22 AM Thread Starter
I didn't even think of that could be a lot of crap from being pressure washed by previous owner. that helps will try that and see how it looks
post #4 of 13 (permalink) Old 07-09-2007, 02:13 AM
I had that happen once, with about 18.5k in tow. The truck got really hot and I had to pull over to let it cool down. Anyways, long story short, I replaced my thermostat and not a problem yet. With a heavy load, the needle will move to just the high side of the middle line. However, I haven't tried a hill that steep with a load that heavy in that kind of heat, since that incident, so I can't say for sure. But also Like Bcummins said, clean everything up really well too.
post #5 of 13 (permalink) Old 07-09-2007, 02:17 AM
Heck look between the two for cardboard! You'll find cardboard from a prevoius owner sometimes there.
Smokem is offline
post #6 of 13 (permalink) Old 07-09-2007, 05:01 AM Thread Starter
thats my project for this week after work. new t stat sounds good too what degree stat is recommended
post #7 of 13 (permalink) Old 07-09-2007, 02:07 PM
TDG Mafia 36
I think the one I got is 195*
post #8 of 13 (permalink) Old 07-09-2007, 03:58 PM
Yeah Napa and Advanced Auto usually has a 195 in stock, Autozone can't get ya anything. FYI I did the checking last winter.
Smokem is offline
post #9 of 13 (permalink) Old 07-10-2007, 03:33 AM Thread Starter
went to kragen today my local parts store was out of them and kragen had a 190 in stock but can order a 180 I went with the instock one for now. but thanks for the help guys. anyone run the wetter water for diesel trucks? I saw that on the shelf when I was grabbing some stuff for my g/f little car.
post #10 of 13 (permalink) Old 07-07-2010, 01:16 AM
cooling issue
I am new guy, excited to get the help and know how. I have a 96 2500, built auto, straight pipe with 2 5" stacks, cold air intake, #5 plate. I have had the same problem - sprayed everything out several times, changed the coolant, replaced the fan clutch since I could never hear it kick on when the temps got hot. Temp is great untill I am pulling 10 K + on hard grades and get to the bottom of 3rd and in 2nd. It wants to redline. I still never hear the fan engage. What will it take to engage it? Should I junk it and get some electric fans if the clutch fan wont work? Any help or advice would be great.
steelpuller is offline
