codes p1388,p1693,p1689 ip? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by golferlid, this thread has received 3 replies and been viewed 1951 times.
post #1 of 4 (permalink) Old 07-12-2007, 07:37 AM Thread Starter
Thumbs down codes p1388,p1693,p1689 ip?
will not start have been told IP but want to make sure 1998.5 5.9 dodge 3/4 ton 2wd 160000k have replaced transfer pump,filter good pressure at inlet to IP but intermitent flow to injectors will start with starting fluid & will restart within a short time after shutoff thankx for your help
golferlid is offline
post #2 of 4 (permalink) Old 07-12-2007, 05:50 PM
You can still have flo to the vp44 and have electrical issue's inside the
pump. Ask me how I know? Just put one on last week.
:smoke
ny
OL RATLR is offline
post #3 of 4 (permalink) Old 07-12-2007, 06:01 PM Thread Starter
did yours have the 0216 code
did you have a 0216 code showing vp44 failure?
thankyou
post #4 of 4 (permalink) Old 07-12-2007, 11:02 PM
P1388 is auto shutdown control curcuit relay,
P1689 Is Something about communication issues between ECM and Injection pump
P1693 is a companion code, DTC in either ECM or PCM. Its there because of the other two.
Its probably the P1689 which could well be caused by internal pump electronics issues.
