2000 dodge cummins wouldn't shut off - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 00'CUMMINS, this thread has received 4 replies and been viewed 832 times.
post #1 of 5 (permalink) Old 07-15-2007, 04:23 PM Thread Starter
A couple of days ago I went camping and after driving up to the camping spot I went to shut my truck off and it wouldn't shut off. So I thought maybe the turbo timer would be on but it wasn't. Finally unplugged the chip and it shut-off. Then I plugged the chip back in and shuts off fine. Just wondering if anyone else has had this problem.
00'CUMMINS is offline
post #2 of 5 (permalink) Old 07-15-2007, 07:08 PM
Thats wierd, I haven't heard of that happening before. I would contact edge and see what they have to say. I don't run the Juice w/A but I run a comp, and from time to time it will do weird things then go back to being perfectly normal. I don't really know what to say, other than talk to edge.
post #3 of 5 (permalink) Old 07-16-2007, 12:17 AM
Bouncer
Like Sean said I would call Edge, anything can happen with electronics.
post #4 of 5 (permalink) Old 07-16-2007, 08:16 PM
I had that same problem but I had to leave the box unplugged. It wasnt killing power to the fuse in the truck. They sent me a new box and a harness cause I had a short at the map sensor connectors. But my suggestion would be to e-mail them, they will call you the next day, Its alot better then waiting on the phone for 45 min.
JayRock is offline
post #5 of 5 (permalink) Old 07-16-2007, 08:49 PM
Exclamation F.y.i.
Well it sounds like you know where your problem is already, and you know you need to get ahold of edge. There are some kind of electronics on the back of the injection pump above the high pressure lines, kind of easy to get to get to. It's a harness type thing that I have plugged into with some kind of Cummins tool that ya hook up to a battery. I'm not sure what it's good for it only checks your high idle. But I know there you have to manually shut it off. So that would be a area worth attention if you run into problems and you have no after market electronics.
Tisk tisk, Electronics aren't all that bad, you just have to get electrocuted a few times to really understand how fun electronics really are.
Smokem is offline
