throwin codes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by xjjeep00, this thread has received 5 replies and been viewed 535 times.
post #1 of 6 (permalink) Old 07-15-2007, 10:28 PM Thread Starter
throwin codes
i got two codes flashing one is companion code and the ather one is lift pump out of ranges i was just wondering what they ment and what all could it be
xjjeep00 is offline
post #2 of 6 (permalink) Old 07-16-2007, 12:08 AM
Bouncer
What are the specific codes?
post #3 of 6 (permalink) Old 07-16-2007, 01:33 AM
p1693 and p0230? I have those codes and my lift pump doesn't work at all.
'01, DRW, Cummins HO, 6spd, hrvp44, holley black, fbd 150hp injectors, edge juice w/ attitude, 4" magnaflow exhaust, Bullseye Power s362 turbo, BHAF, Valair Clutch
blackpsd is offline
post #4 of 6 (permalink) Old 07-16-2007, 01:36 AM
Bouncer
1693 means you have a code. The 0230 tells me that your lift pump is faulty. I would check your connections, but I bet the pump motor has a internal short.
post #5 of 6 (permalink) Old 07-16-2007, 04:04 AM Thread Starter
the pump is only 9 months old would that be a reason my truck doesnt like to start after it sits for awhile accept when its facing down hill cause the pump isnt pumping
xjjeep00 is offline
post #6 of 6 (permalink) Old 07-16-2007, 04:05 AM
Bouncer
Could very well be. Better get it checked out and hope it hasn't already caused damage to your injection pump.
