Fuel Pump - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bada$$dodge2000, this thread has received 6 replies and been viewed 700 times.
post #1 of 7 (permalink) Old 07-16-2007, 02:57 PM Thread Starter
Fuel Pump
Hey whats up guys for the last couple mounths i have been having trouble with my fuel pump. i am just going to break down and buy a new one. write now i dont care what it is. Can you uys tell me what ones you guys recommend kinda give me an idea about whats on the market.
bada$$dodge2000 is offline
post #2 of 7 (permalink) Old 07-16-2007, 05:33 PM
tbroadus_41's Avatar
lift pump or injection pump?
tbroadus_41 is offline
post #3 of 7 (permalink) Old 07-16-2007, 05:34 PM
Blue Chip Diesels or if you have the cash I'd do a P7100 or if possible a P8500! I'm not for sure if that's even fiasble. (P8500)
Smokem is offline
post #4 of 7 (permalink) Old 07-16-2007, 07:03 PM Thread Starter
its the lifter pump
post #5 of 7 (permalink) Old 07-16-2007, 08:32 PM
Bouncer
I personally would just get a FASS and be done with it. Although many are having luck with a big line kit and a pusher pump of your liking.
post #6 of 7 (permalink) Old 07-16-2007, 08:51 PM
Originally Posted by bad*****dodge2000
its the lifter pump
Your sig says you already have a FASS
Smokem is offline
post #7 of 7 (permalink) Old 07-16-2007, 09:34 PM
Aeromotive. Run an A1000, and a couple of aeromotive filter heads and filters. You'll also need a bypass regulator, so you aren't pushing too much pressure. Thats the way I would go. Or you could run a holley and do something similar, or GDP. The one thing I don't like about any of those set ups, is that it seems to take up a lot of space on the frame rail, and I don't know any better clever way to mount them. Maybe if you removed the stock lift pump and filter housing, you could make a custom bracket to hold everything in the engine compartment, I haven't really looked that closely at this stuff.
Other than that, RASP, or Bully dog I believe are your other options.
