Put your thinking caps on....... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Smokem, this thread has received 6 replies and been viewed 594 times.
post #1 of 7 (permalink) Old 07-18-2007, 01:06 AM Thread Starter
Ok my fuel pump did not kick on. This is fact, it hasn't worked for over about year probably. Now, I just got around to trying to find out what was wrong with. Well I didn't, no suprise. So I just re wired the ground and wired up the power to a switch, now it works. Any guess's why it didn't come on? It gets it's power threw the PCM, so............ Did I have a ground problem? Maybe. Did the stupid Crystler PCM stop it from kicking on? Very Possible....
Any guess's???? I have no idea!laugh
Smokem is offline
post #2 of 7 (permalink) Old 07-18-2007, 01:29 AM
Those two sound pretty plausible. Or, possibly a bad connection at the harness it plugs into, thats my only other thought. Or bad wiring somewhere in between the PCM and the pump.
post #3 of 7 (permalink) Old 07-18-2007, 01:30 AM Thread Starter
I was just wondering at the thought of some how the PCM telling the Fuel pump not to kick in for some reason..........
Smokem is offline
post #4 of 7 (permalink) Old 07-18-2007, 04:05 AM
my truck did the same thing took it into the shop and 400 dollars later they finally found the problem it was a bad ground but the thing still only works now and then but thats why I have my holley blue for no worries
01quadcab is offline
post #5 of 7 (permalink) Old 07-18-2007, 04:35 AM Thread Starter
Well I think if the PCM was telling it to shut off, there has to be a reason you wouldn't want the pump running. Anyone got any ideas, of when the pump shouldn't be running. I would think It'd need to bed running all the time the engine is running. Unless somehow the PCM thinks the engine is off, but then I think I'd be throwing all kinds of codes. Like I said before, I'm clueless here. However here's a hint, when I put the key foward, the pump would kick on, for only a split second. But in my opinion that doesn't rule anything out.
Smokem is offline
post #6 of 7 (permalink) Old 07-18-2007, 06:53 AM
Mafia member 46
Dad had a similar issue with his "02, the fuel pump would run correctly until he started driving then it would drop. He replaced the lift pump with a FASS and it didn't help. The IP got replaced (P0216 and 1693 codes) and it still did did it intermittantly. at the end the truck wouldn't run @ all. He had to have the ECM replaced and it was fixed.
Current: '07.5 2500 QC/SB ETJ/68RFE, 4x4, Fabtech 6" lift, KMC XD "Diesel" 20x10 wheels, Pro Comp X all terrain 37x13.5R20 tires, BDog P Pup AFE, MegacannonII, H&S Gen 1 DPF Delete, EGR unplugged. Dynoed 361hp/677tq 20090220
SOLD!'03.5 3500 SRW QC Dynoed 2/11/06 457hp/1002tq
Scrappy is offline
post #7 of 7 (permalink) Old 07-18-2007, 02:31 PM Thread Starter
Interesting.............
Smokem is offline
