will these fit on my truck ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01dezoll, this thread has received 11 replies and been viewed 1053 times.
post #1 of 12 (permalink) Old 07-20-2007, 08:08 PM Thread Starter
33x12.50x17 already have rims that will fit...... wondering if the tires will rub
01dezoll is offline
post #2 of 12 (permalink) Old 07-20-2007, 09:40 PM
If its a 4x4 they'll fit just fine. I'm not sure about a 2wd though.
post #3 of 12 (permalink) Old 07-20-2007, 11:33 PM
they will rub on tight turns but if you get the leveling kit they will not. I run the same size tires but on 16.5 rim and it rubs my plastic parts in the wheel well
01quadcab is offline
post #4 of 12 (permalink) Old 07-22-2007, 06:58 AM
4x4 no problem a friend of mine has 35's on his and it stock with no rub and a bit of breathin room but on the other hand if its 2x4 i belive only 31's will fit well
dustin 08 is offline
post #5 of 12 (permalink) Old 07-23-2007, 11:00 AM
Boost Junkie
I have a 6" suspension lift and my 35's will almost rub in a hard corner at a dead stop. I would say don't go any bigger than a 33' with a stock truck. And not a really agressive tire either.
Josh
91rangerturbo is offline
post #6 of 12 (permalink) Old 07-23-2007, 03:24 PM
:iagree my 33's will run on hard left and hard right turns with stock lift. but when you add the leveling kit upfront it cures the problem
post #7 of 12 (permalink) Old 07-31-2007, 11:26 PM
I was told that a 33 would be fine with a stock lift if you didn't have crazy wheel offsets. I put a 2'' leveling kit on my 01' to be on the safe side and have plenty of clearence befor I put 285's on,however, I didn't think any thing of the I leveling kit (and alot of my buddys have them no problem) but I got lucky enough to get a horrible wobble in the front end , people call the "death wobble", I ended up buying an up graded tracking bar from DT performence. Just be carfull with the leveling kit !! (not to change your thread or nothing, just wish i would have done more home work befor putting that one mine ) good luck! -Ethan
Cummins2001 is offline
post #8 of 12 (permalink) Old 08-01-2007, 12:12 AM
Diesel Mafia #67
blackcloudCTD95's Avatar
I ran 325/65/18's with out a leveling kit on stock lift...
UIm running right now 33x12.50 16.5's:shrug:
Jordan
blackcloudCTD95 is offline
post #9 of 12 (permalink) Old 08-01-2007, 12:13 AM
Diesel Mafia #67
Procomp extretme terrains arent aggressive... I got a pic some where.. of the finished product...:Thumbup:
My truck on 325's.. (procomp 18x10 rim..) then my truck on 16.5's on 33x12.50's hope that helped you.. Ohh then my bald *** procomp extremeterrains they burned up sooo easily!
ID:	11439   Click image for larger version
ID:	11440   Click image for larger version
ID:	11441   Click image for larger version
Jordan
post #10 of 12 (permalink) Old 08-01-2007, 12:55 AM
on my 01 with 33 12.5 16.5 when I turn hard either way it rubbs the plastic innerfender and with the stock rims and 305/75/16 does the same thing
