boosting... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by socal_diesel, this thread has received 38 replies and been viewed 1717 times.
post #1 of 39 (permalink) Old 07-23-2007, 06:25 AM Thread Starter
boosting...
is there anyway to get higher boost by fooling with the turbo instead of buying a new solid chip or programmer or injectors or anything. cause when i step on it the highest i got was 15 lbs. and thats with a larger turbo and a power puck.????????????????????/
please if theres a way let me know!!!!!!!!!!!!!
socal_diesel is offline
post #2 of 39 (permalink) Old 07-23-2007, 07:38 AM
What turbo do you have?
Sounds like the turbo is way to big, the wastegate is way out of adjustment, or you have a boost leak. But thats just what is sounds like to me.
I'm not really familiar w/ 24vs but you should be able to use some thing like a boost elbow, a J-hook, or an adjustable wastegate actuator to control when the wastegate opens.
:2cents
Dual K20s is offline
post #3 of 39 (permalink) Old 07-23-2007, 10:51 AM
Boost Junkie
Yeah i would check for boost leaks first. Cause the factory boost settings on the hy35 and hx35 turbos is 20.5 psi.
Check all of your intercooler piping and couplers then check around the intake on the drivers side of the motor there is a gasket there that could have blow out.
Josh
91rangerturbo is offline
post #4 of 39 (permalink) Old 07-23-2007, 11:36 AM
mrector's Avatar
I'm not 100% sure, but most Cummins powered trucks I've seen, stock, will boost to around 18psi. You may have a pin hole in a boot, or a blown one.
Use the old Ether trick: While idling, just spray little amounts of ether, or CRC, around your boots--if it revs up on it's own, you have a leak.:Thumbup:
Mikey
89 w250 project truck
mrector is offline
post #5 of 39 (permalink) Old 07-23-2007, 12:37 PM
Boost Junkie
Yes you were correct.. Sorry for this mis-information.
Ram Diesel Turbocharger Specifications
Model Engine Max Boost Turbocharger
98-00 ISB 235 HP 17.7-18.2 psi Holset HX35W 12 sq cm turbine housing
2000 ISB 235 HP 17.7-18.2 psi Holset HY35W 10 sq cm single port turbine housing
Sourced From Here.
http://dodgeram.org/tech/dsl/Facts/98ISBspecs.html
Josh
post #6 of 39 (permalink) Old 07-24-2007, 02:53 AM Thread Starter
the turbo IS after market and on the turbo housing it says "schwitzer" but when i lay into it and shift i hit 15 lbs of boost. my friend said it could be a boost leak but i dont know were it could be. i dont know what kind of turbo it is cause i bought the truck with it. the plate on the turbo says HT(somthing)2. idk what kind it is
post #7 of 39 (permalink) Old 07-24-2007, 02:58 AM
Official TDG Doctor
hccumminssmoke's Avatar
your not giving it enough fuel to create the boost I think you want...theres no way a power puck is going to do that for you...when you take off what are your RPMs? it may just be simple lag? do you have a tag for model number or anything for the turbo?
Nathaniel
hccumminssmoke is offline
post #8 of 39 (permalink) Old 07-24-2007, 03:04 AM
diesel_ram_man's Avatar
Images: 6
I think the Power Puck does mostly timing, you have to much air and not enough fuel. You need at least a Edge Comp IMO. And may I ask why you want so much boost?
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #9 of 39 (permalink) Old 07-24-2007, 03:09 AM Thread Starter
idk i just more boost cause its not getting what it should.....i have stock injectors but my dads mechanic says it needs new injectors with that new turbo so hes getting me his new stage 3 injectors.
post #10 of 39 (permalink) Old 07-24-2007, 03:10 AM
Images: 6
Some stage 3's would definatly help out a lot. :Thumbup:
Can You Keep Up??
