Upgrade Compressor Housing - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by payne86, this thread has received 1 replies and been viewed 574 times.
post #1 of 2 (permalink) Old 07-26-2007, 03:41 PM Thread Starter
payne86's Avatar
I was looking at these. Do they help very much or not? id prob be better off just buying a dif turbo cause i no it will help. I met a guy who had an 01 with edge comp and 100hp sticks and he had a different compressor housing and said that it only gets past 1200 when pulling a loaded gooseneck. forgot to ask which level he was on the edge.
2006 Chevy Duramax LBZ 4x4 2500 Regular Cab. 5inch exhaust,everything else is Bone Stock for now............................... SOLD......2001 Dodge 2500 4x4 Regular Cab Cummins. Ats intake horn,Ats Exhaust Manifold, AFE stage II intake, Edge Comp, Superchip,FASS 95,Luk clutch(450),boost elbow,5in turbo back stait piped. silincer ring lost, 2in levelingkit 305/70/16 on 16-10.
payne86 is offline
post #2 of 2 (permalink) Old 07-26-2007, 03:52 PM
They help at higher rpms. They aren't that good for towing since you the low end. They are a trade off, you loose low end and gain top end cooling. The more low-end you give up the more top-end you gain. I think of them as a temporary fix untill you save the money for a real turbo.
Even w/ a bigger turbo you trade low end for top end but a bigger turbo also has a bigger compressor and can supply more air instead of just letting more exhaust out. Thats just my take on housings though.
:2cents
Dual K20s is offline
