12Valves? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by pb_beaker, this thread has received 16 replies and been viewed 955 times.
post #1 of 17 (permalink) Old 07-27-2007, 06:24 PM Thread Starter
Question 12Valves?
Did dodge make any 12 valve engines after 98?
pb_beaker is offline
post #2 of 17 (permalink) Old 07-27-2007, 06:33 PM
no 98 was the last year.
Smokem is offline
post #3 of 17 (permalink) Old 07-27-2007, 06:34 PM
diesel_ram_man's Avatar
Images: 6
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #4 of 17 (permalink) Old 07-27-2007, 09:09 PM
Bouncer
In trucks no, although I am fairly certain they still produced 12v industrial engines for various applications.
post #5 of 17 (permalink) Old 07-28-2007, 01:42 PM
They still make the industrial, becuse we have a 2005 agco spyder sprayer and it runs the 12v. I have also seen 12v's on some newer front end loaders.
StrokeThisGoat is offline
post #6 of 17 (permalink) Old 07-28-2007, 02:45 PM
Mafia member 46
Current: '07.5 2500 QC/SB ETJ/68RFE, 4x4, Fabtech 6" lift, KMC XD "Diesel" 20x10 wheels, Pro Comp X all terrain 37x13.5R20 tires, BDog P Pup AFE, MegacannonII, H&S Gen 1 DPF Delete, EGR unplugged. Dynoed 361hp/677tq 20090220
SOLD!'03.5 3500 SRW QC Dynoed 2/11/06 457hp/1002tq
Scrappy is offline
post #7 of 17 (permalink) Old 07-28-2007, 03:22 PM
Official TDG Doctor
hccumminssmoke's Avatar
Yea AGCO has been running a Cummins exclusivly for about 6 or 7 years now I think...I saw an ad for one of their larger tractors (like a JD 6k series) and it was running the 5.9 600 series...and you can still buy a crate motor i believe
Nathaniel
hccumminssmoke is offline
post #8 of 17 (permalink) Old 07-28-2007, 04:41 PM
yes you can still get them, theres a few heavy equipment companys that use them too, hyundai, samsung (did im not sure about the volvo models that replaced samsungs), kawasaki, case and a few others all still use the 12v's
DBogo is offline
post #9 of 17 (permalink) Old 07-28-2007, 08:20 PM
Bouncer
The 6BT was actually developed as a joint venture with Case/Cummins for use solely in Case construction equipment back in the early 80's. Obviously, it has since spread out to other manf.
post #10 of 17 (permalink) Old 07-29-2007, 01:53 AM
Isn't it older than that? I could have soarn I seen box trucks with 4BT's from the 70's. Not for sure on that one. I thought it got started out in mining too.
Smokem is offline
