5.9 vs. 6.7 pulloff - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dustin 08, this thread has received 14 replies and been viewed 1068 times.
post #1 of 15 (permalink) Old 07-29-2007, 07:17 AM Thread Starter
5.9 vs. 6.7 pulloff
alrite all my buddies were talkin bout pullin off with each other and we've got an 02' dodge single cab 2x4 1 ton dually stock and my buddies dad has an 06' dodge 1 ton dually 4 door 4x4 with the 6.7 mine is manual and his is automatic and stock as well and he said we need to get our trucks and have a pulloff i said no you'd out pull me he said why oh cuz mine is a quad cab what the hell yes joe thats exactly why it so damn stupid its hilarous im sorry he's one of my best friends but when god was passin out the brains he was hidin and didnt get 1 at first i thot he was jokin but no he was bein serious
dustin 08 is offline
post #2 of 15 (permalink) Old 07-29-2007, 01:47 PM
keep ot even and stay out of 4x4
Cold fodged is offline
post #3 of 15 (permalink) Old 07-29-2007, 08:17 PM Thread Starter
well do you think that would be even the 600 vs. the 650 but he does have an automatic so that is a little advantage for me in a sense
post #4 of 15 (permalink) Old 07-30-2007, 05:42 AM
Power isn't the biggest thing, weight is. A few saturdays ago we hooked a 06 dodge 5.9 quad cab to an 01 chevy 6.0 gas quad cab with almost 200,000 miles. The chevy had a welder, air compressor, and was loaded with tools and the dodge was empty. They had identical BFG's. With both trucks in 4 lo, the chevy had no trouble out pulling the dodge. So if you do pull, make shure you have all kinds of weight on the back axle.
StrokeThisGoat is offline
post #5 of 15 (permalink) Old 07-30-2007, 05:48 AM Thread Starter
thanks for the input cuz i no for sure he's got me on weight now those new dodge duallys swollow our 02' his is quab and ours is single so i guess ill jus put a ton of weight in it if we do
post #6 of 15 (permalink) Old 07-31-2007, 01:34 AM
help me decide
i AM THINKING OF BUYING A DODGE. sHOULD i GET THE 5.9 WITH TJE 4 spped auto or the 6.7 with the 6 speed auto??
:shrug: :shrug:
nicelawn is offline
post #7 of 15 (permalink) Old 07-31-2007, 02:08 AM
First off, if his is an 06 its not a 6.7L. Second, traction and height is much more important. If you both hook to your hitches, and his truck is taller, you will never win. You will be pulling him down giving him more traction and he'll be lifting you giving you less traction. If you load up over your rear axle that would help. But I doubt he'll let you keep a ton of cement in your bed. Hooking up and trying to pull eachother backwards just sounds like a great way to break your truck and prove nothing. Except who had more traction.
post #8 of 15 (permalink) Old 07-31-2007, 03:36 AM
TDG Mafia
Jeffybuilt's Avatar
Singles Club #247
TDG Mafia Member
Thanks To:
(269) 663-8571
Jeffybuilt is offline
post #9 of 15 (permalink) Old 07-31-2007, 06:15 AM Thread Starter
im sorry i meant 2007 6.7 and yes he's not very bright he would let me put a ton of concrete in my truck but no i wasnt gonna pull off with him he just mentioned it and about the height thing he has a huge drop hit mine is only like 2 inches at the most so thats not gonna affect anything
post #10 of 15 (permalink) Old 07-31-2007, 01:24 PM
payne86's Avatar
hooking up proves nothing. i have hooked my other truck, an 87 toyota truck up to an F150 before and won. My toyota had a 4cyl then with 31s and open diff, F150 was a 86. Yes weight is everything but using the brake and watching for his brake lights is the key, if you hook up and he is on the brake, then ride the brake till his brake light comes off then go, your not going to pull him if he has his brakes locked. but if i was you i wouldn't even try it, unless you want a broken driveshaft or something
2006 Chevy Duramax LBZ 4x4 2500 Regular Cab. 5inch exhaust,everything else is Bone Stock for now............................... SOLD......2001 Dodge 2500 4x4 Regular Cab Cummins. Ats intake horn,Ats Exhaust Manifold, AFE stage II intake, Edge Comp, Superchip,FASS 95,Luk clutch(450),boost elbow,5in turbo back stait piped. silincer ring lost, 2in levelingkit 305/70/16 on 16-10.
payne86 is offline
