Weird Sound - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by TeamTonkadodge, this thread has received 9 replies and been viewed 764 times.
post #1 of 10 (permalink) Old 07-29-2007, 03:02 PM Thread Starter
TeamTonka
Send a message via MSN to TeamTonkadodge
Weird Sound
Jus wondering if yall might know whats wrong. Thers a constant winding, whistling sound coming from somwhere in my drivetrain, it a 5speed '02 dodge 2500. It just started recently and doesent seem to be affecting anything its just annoying. appreciate it.
lata
2002 3/4 ton CTD 4x4. 5 spd. jus straight piped for now. Want a edge programer.
"No Stoppin Team Tonka"
TeamTonkadodge is offline
post #2 of 10 (permalink) Old 07-30-2007, 05:35 AM
I guess it could be some input/output/ or throwout bearing on the tranny. Could be a boost leak if it happens under boost. Have you checked the power steering fluid? sometime they have a winding noise.
StrokeThisGoat is offline
post #3 of 10 (permalink) Old 07-30-2007, 01:54 PM
check all your drive train fluids and possibly change them if they are low and/or burnt. does it only make the sound when your moving? and lastly have you installed a cold air intake recently?
redneckchief is offline
post #4 of 10 (permalink) Old 07-31-2007, 02:11 AM Thread Starter
TeamTonka
It only makes it when i move. Now that you mention it it might actually be the throwout bearing. It sounds like its coming from under the truck. Ill take a look at it. Any more help would be appreciated.
lata
post #5 of 10 (permalink) Old 07-31-2007, 01:58 PM
a throw out bearing should only spin when you push in the clutch u-joints are another possibility and if drivetrain oils were good it is possible to toast a bearing but unlikley check your brakes you might have something hanging up
post #6 of 10 (permalink) Old 08-02-2007, 03:44 AM
Bouncer
Ring gears are known for making a whining sound if something comes out of adjustment or low on fluid. Could also be a carrier bearing.
post #7 of 10 (permalink) Old 08-02-2007, 07:12 PM
02sprtcumns's Avatar
:iagree
02sprtcumns is offline
post #8 of 10 (permalink) Old 08-02-2007, 10:14 PM
That is what my truck is doing and it is driving nuts. Its shifts fine and runs as good as ever just this load humming sound from under my truck.
marlena4syth is offline
post #9 of 10 (permalink) Old 08-03-2007, 02:28 AM
I would check the rear diff. Pull the rear cover and check that first.
12vbowtie2 is offline
post #10 of 10 (permalink) Old 08-07-2007, 04:43 AM
02RAMCTD6SPD
Send a message via AIM to CumminsBlckSmk
I had sort of the same problem and it ended up being the carrier bearing on my driveshaft. I drive an 02' ext.cab, longbed. Not sayin its the problem but would check it out in case.
CumminsBlckSmk is offline
