Anybody have an htb2 62 turbo? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by payne86, this thread has received 25 replies and been viewed 2746 times.
post #1 of 26 (permalink) Old 07-31-2007, 08:56 PM Thread Starter
payne86's Avatar
I was wondering if anybody had that turbo with around 100 hp injectors w/chip or programmer. I was wondering what kind of egts to expect if i am unloaded and when i have 10,000+ behind me. And if i can run my stack and how high i could prob tow with on my comp while keeping egts in check.
2006 Chevy Duramax LBZ 4x4 2500 Regular Cab. 5inch exhaust,everything else is Bone Stock for now............................... SOLD......2001 Dodge 2500 4x4 Regular Cab Cummins. Ats intake horn,Ats Exhaust Manifold, AFE stage II intake, Edge Comp, Superchip,FASS 95,Luk clutch(450),boost elbow,5in turbo back stait piped. silincer ring lost, 2in levelingkit 305/70/16 on 16-10.
payne86 is offline
post #2 of 26 (permalink) Old 07-31-2007, 10:09 PM Thread Starter
payne86's Avatar
O and what kinda hp i would put on the dyno.
payne86 is offline
post #3 of 26 (permalink) Old 07-31-2007, 10:26 PM
diesel_ram_man's Avatar
Images: 6
With the injectors, comp, and htb2 turbo around 400-415
The Diesel Garage.com
Can You Keep Up??
diesel_ram_man is offline
post #4 of 26 (permalink) Old 07-31-2007, 10:38 PM
Cummins Man
Dazedandconfused's Avatar
Pm Teddybear on here if you want to buy one. He had one for sale.
Andy
04 Duramax
93 Dodge D-250
91 Dodge D-350
84 Dodge D-150
Dazedandconfused is offline
post #5 of 26 (permalink) Old 08-01-2007, 12:09 AM Thread Starter
payne86's Avatar
Im sorry i didn't mean for it to sound like i was asking to buy one from somebody, i ment if anybody had a setup like i described so they could tell me about the egts and such.
payne86 is offline
post #6 of 26 (permalink) Old 08-01-2007, 12:41 AM
We used a similar turbo on an 01. It was a bell USB which is another S300 variant with a 62mm comp wheel like the htb2 62. However, it had a big ex. housing and IMO was laggy, even with a comp, HRVP44, and 150hp sticks. It would spool fine when unloaded, but it wouldn't spool quick enough towing, and would get really hot down low. Also, It wouldn't provide enough air to keep that below 1600*, but thats a lot of fuel, and IIRC it was a non wastegated ex.
I would think a 62/13 would be a nice set up for a comp and 100hp sticks. It should spool faster with the 71mm ex. turbine, and the dual ported wastegate will keep it cooler up top. I would imagine you would want to turn down the sublevels on your comp when towing above 10k. Maybe not though. It should definitely be managable though.
I would put you in the mid 400's on the dyno. But it really depends on the dyno, I have seen dyno's that give really low numbers compared to what calculations based on ET or trap speed and weight produce.
post #7 of 26 (permalink) Old 08-01-2007, 01:32 AM
I have pretty close to the setup your planning on, including the htb2. My egt's vary considerably. I have hit 1500 degrees racing with the comp on 5x5. The edge injectors are not the greatest though. I see temps about 750 to 800 while at crusing speeds and I usually don't tow anything below about 15000 but my egt's will hit 1350 with no problem pulling hills with the box off. That is going about 55 in 5th gear though, kinda luggin the motor but I don't like to tow very fast. Down in 4th it pulls like a champ at 55 but likes to drink fuel. However when not lugging the motor and pulling the same load at 70 egt's aren't bad.
01 Qc Cummins 4x4 long box, edge attitude with juice (HOT!!), 4" exhaust, afe stage 2 intake, HTB2 62/12, banks intake pleum, bully dog big fuel kit, stage three jammers, southbend 3250 DD, BD Blow off valve. PDR master and slave cylinder upgrade. Sold
2006 mega cab 4x4 auto. Stock for now.
bad_cummins is offline
post #8 of 26 (permalink) Old 08-01-2007, 02:31 AM Thread Starter
payne86's Avatar
ok thank you, i would plan on getting scheid stage 1 injectors. Are you pleased with the turbo or would u wish you had something else? ill go ahead and ask a dumb ? though, i always let off when i see my egts get past 1200 but ive read on here you guys running up to 1500 and 1600, is that just a huge risk or ? i don't want to pull a trailer and get past 1200. so mabey just smaller injectors or a different turbo than the htt?
payne86 is offline
post #9 of 26 (permalink) Old 08-01-2007, 02:39 AM
You're safe to run 1200-1250 all day long. above that you just want to do it for short bursts. The hotter you get, the short you should stay in it. I'm going to run 200hp sticks in my truck and I occassionally tow up to 18-20k in very steep hilly terrain. Thats why I'm going with a twin turbo set up. Hopefully its enough to keep me cool, so I don't have to back out of the throttle. Right now, I'm running 65hp injectors and a comp box on my stock turbo, and have been able to keep EGT's managable towing 18.5k up a 13% grade for 2 miles. You'll want to run more timing and less fuel, and you should be able to do just fine.
post #10 of 26 (permalink) Old 08-01-2007, 02:42 AM Thread Starter
payne86's Avatar
What size tires do you have on your truck bad_cummins? i have 285s and at 70 mph i am only 1900 rpms. i could see why you are getting those egt if you keep it in 5th and that slow mph. how long can you stay into the throttle though? do you have to ease into each hill and ease off all the way or can you just keep it to the floor for along time before you have to let off, lets say you are over 2000rpms.
payne86 is offline
