boost fooler or not - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 199eightcummins, this thread has received 17 replies and been viewed 3768 times.
post #1 of 18 (permalink) Old 08-08-2007, 02:24 AM Thread Starter
boost fooler or not
Alright so I have been thinking about getting a boost fooler after I just recently bought a superchips and I am only seeing about 19 max boost. So do you think its worth it. I would also like some prices to :Thumbup: I would also like some dislikes and like if anyone is running one.
199eightcummins is offline
post #2 of 18 (permalink) Old 08-08-2007, 02:59 AM
03cmmns's Avatar
Wire the map sensor hot. Worked good in my buddies 00.
03 2500 Ram 4x4 Reg Cab-Diablo Sport Predator/Puck,BHAF,Isspro Pyro,Boost,Trans Temp,Fuel Psi,HTS Race Build Tranny, Suncoast Converter,Silverline Exhaust,BD Lift Pump, 3/8" Fuel Line, Homemade Filter Setup,free mods.
03cmmns is offline
post #3 of 18 (permalink) Old 08-08-2007, 03:00 AM
i am not sure but i do believe that the superchips has the boost fooler built it. if not then check out an A.D.D. device from Scheid. they are only 60 bucks. If you are planning on upgrading to a bigger box though most boxes have a boost fooler built in. i believe all of the edge boxes have boost fooler.
MOOSE 04 is offline
post #4 of 18 (permalink) Old 08-08-2007, 03:05 AM Thread Starter
I dont think it does because should I be seeing more than just 19ilbs? Maybe not I dont know but, for right now I just plan on bosch 300's and then I dont know what next but, I will check out the schied fooler at there extravaganza.
post #5 of 18 (permalink) Old 08-08-2007, 03:32 AM
payne86's Avatar
when i just had the superchip i was hittin around 20 max, put a boost elbow around 27, comp with superchip hits around 32 on 5-5. comp box came with another boost elbow to.
2006 Chevy Duramax LBZ 4x4 2500 Regular Cab. 5inch exhaust,everything else is Bone Stock for now............................... SOLD......2001 Dodge 2500 4x4 Regular Cab Cummins. Ats intake horn,Ats Exhaust Manifold, AFE stage II intake, Edge Comp, Superchip,FASS 95,Luk clutch(450),boost elbow,5in turbo back stait piped. silincer ring lost, 2in levelingkit 305/70/16 on 16-10.
payne86 is offline
post #6 of 18 (permalink) Old 08-08-2007, 03:37 AM
payne86's Avatar
o and that little brass boost elbow droped my egts by 100degress on top. i use to be able to wot and could hit 1200 and after i but the elbow i can go from a stop to 110mph on flat and it stays on 1100 and never went past,with comp turned off, but as in my sig. i do gave more stuff to help it breath and flow better.
payne86 is offline
post #7 of 18 (permalink) Old 08-08-2007, 03:42 AM Thread Starter
Can I have some more info on this elbow your talking about.
post #8 of 18 (permalink) Old 08-08-2007, 06:34 AM
Yeah, the elbow is the reason you aren't seeing higher boost numbers. All a boost fooler will do is keep you from throwing a code when you hit those higher numbers. The elbow has a smaller or adjustable oriface than stock which keeps the wastegate closed longer and allows you to build more boost. On a stock truck you don't really need one because you don't have extra fuel to burn. They can be picked up for anywhere from $20-30. Rip Rook sells them. Here is a link to the ones he sells.
http://www.sourceautomotive.biz/sa_dodge-turbo.htm
post #9 of 18 (permalink) Old 08-08-2007, 09:42 PM
payne86's Avatar
I was told that some will throw the code and some won't. When i have comp on 5x5 and turbo builds boost it hits 32psi fast and then drops back down to around 27psi, does that sound like its reading overboost and defueling? i can't tell power loss cause right when it starts to drop i have to shift.
payne86 is offline
post #10 of 18 (permalink) Old 08-09-2007, 02:49 AM
If its defueling, you will notice that your EGT's will drop too. However, having the wastegate open up on you will also make it drop. Try plugging the wastegate line and see if it still happens. If it still happens, then its probably defueling, or the spring in your wastegate accuator could be shot.
I think over boost will throw a code. If you're not throwing a code, I doubt you're over boosting.
