Surging Question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by drummerboydw, this thread has received 6 replies and been viewed 512 times.
post #1 of 7 (permalink) Old 08-08-2007, 04:00 PM Thread Starter
Surging Question
I have went through the steps of taking the cables loose and resetting the sensor. It works good for maybe a week then I have to do it again. My question is could I just buy a new one and install it to fix the problem or is it triggered by something else. it gets old after a while. Thanks for all the great help you gys always come through with.
drummerboydw is offline
post #2 of 7 (permalink) Old 08-08-2007, 05:19 PM
tbroadus_41's Avatar
we need a little more info on the problem.
tbroadus_41 is offline
post #3 of 7 (permalink) Old 08-08-2007, 07:44 PM
Official TDG Doctor
hccumminssmoke's Avatar
:dodge
hccumminssmoke is offline
post #4 of 7 (permalink) Old 08-08-2007, 08:37 PM
T.D.G. Mafia Member #88
cumminspride's Avatar
If its the apps sensor you are talkin about heres a cheap fix and I'm doin it to my 03 tonight in hopes of curing a surging issue with dead pedal http://www.dodgeram.org/tech/transmi...TPS_adjust.htm hope this is what you were shoppin for:Thumbup: !
cumminspride is offline
post #5 of 7 (permalink) Old 08-08-2007, 09:56 PM Thread Starter
sorry about the info, yes I was speaking of the throttle positioning sensor. I take the battery cables off and let it set for hours and go through the rest of the steps. It cures the problem for maybe 2 weeks at a time before reoccurring. The transmission is in good shape and works great when this is not going on. What I was wanting to know was if I just replace the sensor instead of resetting it would that cure the problem or is there something else that causes thisa to happen so much. Thanks again for all the help
post #6 of 7 (permalink) Old 08-08-2007, 11:02 PM
It might fix it but it could also be noisy wiring also so i would recomend trying the capacitor first cause if you replace that tps or apps then you still have to set it with a digital volt meter1:Thumbup:
post #7 of 7 (permalink) Old 08-12-2007, 01:58 AM Thread Starter
I talked to a diesel shop about repairing this surging and he said he could install a noise filter for 110.00 that would correct the problem. Honestly guys I think I can do that myself only thing is I'm not sure exactly what part it is I need to install. Any help on that would be appreciated. Thanks for all the responses all you guys at diesel garage rock.
