2 cycle oil - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Diesel Fanatic, this thread has received 15 replies and been viewed 1338 times.
post #1 of 16 (permalink) Old 11-25-2007, 06:40 PM Thread Starter
TDG Mafia 36
Diesel Fanatic's Avatar
Send a message via Yahoo to Diesel Fanatic
2 cycle oil
Is there a difference between 2 cycle oils? I went to Walmart the other day, and saw 2 cycle oil, and then out board 2 cycle oil. Is there a difference?
Brandon AKA bcumminsmeck
Diesel Fanatic is offline
post #2 of 16 (permalink) Old 11-26-2007, 05:09 AM
there is a difference in them one is for hotter burning engines that rev higher and I believe it was a ash formula and the other is for more mild 2 stroke motors and it's either low ash or ashless. contact moparman he will have the answer. I just run the cheap supertech 2stroke oil.
01quadcab is offline
post #3 of 16 (permalink) Old 11-26-2007, 05:13 AM
http://mopar.mopar1973man.com/2002%2..._cycle_oil.htm
link to his 2 stroke info
post #4 of 16 (permalink) Old 11-26-2007, 12:02 PM
2nd Gen Guru
Mopar1973Man's Avatar
Dang... You beat me to the punch....
This is the one most are using..
As long is its ASHLESS & TCW-3 you good...
Mopar1973Man is offline
post #5 of 16 (permalink) Old 11-26-2007, 03:56 PM
bummer I didn't know there was different 2 cycle oil. Hopefully I've been putting the right stuff in.
Smokem is offline
post #6 of 16 (permalink) Old 11-26-2007, 09:29 PM
Yep tc-3 non syn ashless you are good to go. I use a oil rom citgo Used for outboard boat eng and snowmobiles.
2001 Dodge quadcab 4x4,Auto transmission,Fass 150/150 pump, Among other upgrades.
todt061458 is offline
post #7 of 16 (permalink) Old 11-29-2007, 11:54 AM
Does the two stroke oil really help that much? I've read alot about it some say that it helps and some say that it doesn't.
99 2500 dodge cummins, HTS auto trans, quadzilla/edge ez, edge stage 2 nozzles, HX40,special X pump, big line kit, custom dual filter intake, custom exhaust, holley blue, adjustable boost elbow, new intercooler boots, t/c lock up switch, suncoast t/c, leveling kit, new 285 bfg's, all the gauges. New TPS
SINGLES CLUB MEMBER #44
iwannagofast is offline
post #8 of 16 (permalink) Old 11-29-2007, 05:32 PM
It does, wait for your VP44 to start acting up. Then add some. :Thumbup:
Smokem is offline
post #9 of 16 (permalink) Old 11-29-2007, 09:33 PM
I read one of mopar1973man's web pages. Does the 2 cycle oil increase the btu's? I was able to figure out that it does increase the lubricity, but what can I add during the winter to keep the fuel from gelling and not counter act the 2 cycle oil?
Also, I feel like a complete dumb***** asking but, what does my tank hold exactly?
post #10 of 16 (permalink) Old 11-29-2007, 09:51 PM
just wondering how yall are dishing out the oil for each tank, i get the whole 1 ounce/gal but interested if anyone's got an easy dosage method?
hemichallenger is offline
