2 stroke oil ? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 7.3stroker, this thread has received 3 replies and been viewed 798 times.
post #1 of 4 (permalink) Old 12-28-2007, 07:54 PM Thread Starter
2 stroke oil ?
i hear alot of people talking about putting 2 stroke oil in their fuel wat are the advantages of this are there any disadvantages and does it matter wat kind you use and how much do you use
97 f 250 xlt 4 inch lift, 36/15.50 tires, hypermax kit with sledghammer turbo, swamps 355mm injectors, compitition fuel system,bdp stealth pumps oil system, head studs, custom 4 inch exhaust, edge evo and ez stack
7.3stroker is offline
post #2 of 4 (permalink) Old 12-28-2007, 07:58 PM
ohhh, you just asked for it, as soon as moparman posts up you'll have your reading for a long time, but till then
one ounce per gallon of fuel, and it lubes your fuel system because the new ulsd took a good bit of the lubricative qualities out, these qualities are needed by these older engines, the 2-strkoe is oil, it helps a lot, it'll make the engine run better, quieter, and smoother, it's good for it, walmart 2-stroke, I think there's some criteria, just can't remember
cajuncummins is offline
post #3 of 4 (permalink) Old 12-28-2007, 11:32 PM
2nd Gen Guru
Mopar1973Man's Avatar
If you want the low down just flip over to my site and start reading...
http://mopar.mopar1973man.com/2002%2..._cycle_oil.htm
As for dosing... typically its 1 ounce of oil for every 1 gallon of fuel...
http://mopar1973man.com/other%20files/PDF/mixratio.pdf <- Ratio Table
The I highly suggest you don't mix other additive with 2 cycle oil unless it got a LOWER HFRR number... Here is a table of mixing additive if its RED it a failed mixture, yellow pass gov't standard, green passes both manufacture and gov't standards...
(This table is calculated averages of HFRR numbers... Based of Diesel place.Com data)
As you see adding other products to the 2 cycle oil really does change the ability of the 2 cycle oil fast...
Mopar1973Man is offline
post #4 of 4 (permalink) Old 01-01-2008, 10:57 PM
moprr71's Avatar
I started using 2 stk oil in my truck about 1000 miles ago. I noticed a little throttle response improvement, the truck runs a little smoother and quieter. The sound is slight but i will take any noise reduction that i can get.
97 jeep, 4BT,D60s,ARBs,NV4500,atlas,42 swampers
98 grail 12 valve, quad cab, short bed, 4x4, auto, no mods at all.
moprr71 is offline
