5" exhuast - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by nepsd, this thread has received 10 replies and been viewed 1060 times.
post #1 of 11 (permalink) Old 12-31-2007, 03:00 PM Thread Starter
5" exhuast
Possibly getting a 5" MBRP exhuast, any issues with drone going with this on an other wise stock 98.5 24v dually? I will also be getting a 3 piece manifold, and air intake.
1999 Ford F350 XLT ex. cab 4X4, 6 speed, manual hubs, build date 7-98
2009 Ford Flex limited
2002 ford ranger 4X4 lifted, 35's
1998 Dodge 3500 2wd, cummins, auto tranny, quad cab, 312000 miles (sold)
1996 Cadillac Northstar power
nepsd is offline
post #2 of 11 (permalink) Old 12-31-2007, 03:52 PM
does it have a muffler? if it does you shouldn't have any problems, but if it's just the pipe then there will be a drone at a certain rpm
cajuncummins is offline
post #3 of 11 (permalink) Old 12-31-2007, 08:09 PM
No issues, not sure what drone is though. It'll make it sound like a beast though.
Smokem is offline
post #4 of 11 (permalink) Old 01-02-2008, 10:21 AM
02sprtcumns's Avatar
It does sound like a beast. Also my spare tire wont fit under the truck any more with 5" exhaust.
02sprtcumns is offline
post #5 of 11 (permalink) Old 01-02-2008, 03:02 PM
Bouncer
There is always a certain amont of drone with any straight exhaust systems on our trucks. Every truck is different as to where the drone is the loudest. Also the larger you go in size, the louder the drone gets. However even with a 5" it is not anywhere near unbearable.
post #6 of 11 (permalink) Old 01-02-2008, 09:21 PM
Forgot to mention that.
Please explain what "the drone" is suppose to sound like?
Smokem is offline
post #7 of 11 (permalink) Old 01-02-2008, 09:53 PM
haz-mat19's Avatar
Its like a constant low hum, same as the rpm, its hard to describe, but that is as close as I can get. And why a 5", it is kind of big for a stock truck, you would be fine with a 4":2cents
'01 xcab 4x4,Suncoast by Mike L. Goerend triple, edge III, AFE stage II, HTT 62/12, FASS, and other stuff
haz-mat19 is offline
post #8 of 11 (permalink) Old 01-03-2008, 03:33 AM
it's when you hit the right rpm and the reverberations in the exhaust get just right and it's this low rumble that you can feel as much as you can hear, it gets kinda annoying
post #9 of 11 (permalink) Old 01-06-2008, 05:56 AM
Yeah its that sound that seems to fill you ears, even though its not that loud. Only happens at the right conditions though.
Also the outlet on the turbo is only 2.5" so 5" is a little big..... but they are cool
Dual K20s is offline
post #10 of 11 (permalink) Old 01-06-2008, 06:41 AM
tbroadus_41's Avatar
the drone on my my 4 inch straight happens about 2200 rpm in 5th gear it's not real bad because i'm used to it but those who ride in my truck think it's about as annoying as my fass pump. Although my 4 inch is no where near as bad as my buddies 6 inch stacks used to be.
tbroadus_41 is offline
