5 spd trans problem - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Kleiner, this thread has received 1 replies and been viewed 547 times.
post #1 of 2 (permalink) Old 01-26-2008, 07:06 PM Thread Starter
5 spd trans problem
i have a 01 w. 130,000 on it. several months ago when we would pull a heavy trailer a long distance say 1 hour it would be hard to put in 1st, 2nd, and reverse from a dead stop. if you were rolling a little, you could get in into gear. now it does it about all the time, not just when it is really hot. syncronizers, clutch, ?????????????? this is one of our work trucks that pulls a bobcat or a enclosed trailer 5 days a week.
2006 ram 3500 drw, fully built all billet auto tranny, 5" exhaust, smarty, edge ez, tst, aurora 5000, head studs, sheids cam, ciramic coated pistons, cold air, water meth, fass 150, 100 hp DDP injectors, NX 2 stage nitrous kit, gauges pyro, trans, 100 psi boost, fuel pressure, nitrous pressure
Kleiner is offline
post #2 of 2 (permalink) Old 01-27-2008, 09:25 PM
bmoeller's Avatar
Changed the trans fluid lately? Works for some guys.
May need to change the fluid in the clutch reservoir, or there might be air in the system. Low fluid?
Master/slave cylinder problem?
Problem with the pilot bearing (bushing) stuck on input shaft or throwout bearing?
Warped clutch disc?
"Obama = Hoax and Chains"
bmoeller is offline
