2001 cummins auto 2500 - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 99_stroker, this thread has received 2 replies and been viewed 834 times.
post #1 of 3 (permalink) Old 02-11-2008, 03:54 PM
99_stroker
my friend just bought this truck from decorah iowa it has 116000 miles on it and he paid 15 k for it wat do u think of the deal???? and hes wondering wat the dp tuner of cummins is. Im a ford guy and hes just wonderign wat the pest chip for an 01 cummins 2500 is thanks:smoke
post #2 of 3 (permalink) Old 02-11-2008, 04:25 PM
sounds fair, but did he check fuel pressure at all yet? If the auto is all stock I would not recomend any more than what an edge ez will put out for power. If he is planning on building the trans later then go with an edge juice with attitude and get a pusher pump to keep the fuel pressure in the right specs. depending on what the truck was used for before it could be getting ready for a tranny.
01quadcab is offline
post #3 of 3 (permalink) Old 02-12-2008, 02:21 AM
the dp tuner of the Cummins 24v vp44 trucks are www.bluechipdiesel.com but make sure the fuel pressure never dips below 10 psi and make sure to take care of the tranny before you do anything too hard on it
cajuncummins is offline
