02 1 ton tow truck? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by layzboy2011, this thread has received 17 replies and been viewed 1427 times.
post #1 of 18 (permalink) Old 03-11-2008, 11:09 PM Thread Starter
layzboy2011's Avatar
02 1 ton tow truck?
hi, i am looking to purchase a tow truck... the question is does anybody have any expierence with the automatic tranny in a simular application? if so should i even try it? also it needs to be a 4x4 if that makes any difference. thank you.
layzboy2011 is offline
post #2 of 18 (permalink) Old 03-11-2008, 11:14 PM
Not sure what your asking but it's a 47RE fun tranny to get to know. If it's all stock right now, it's probably all junk. But after mods they can be pretty nice trannys.
Smokem is offline
post #3 of 18 (permalink) Old 03-11-2008, 11:32 PM Thread Starter
As i have not picked a specific truck yet, it is safe to assume that it will be all stock. so what kind of mods are needed to make it RELIABLE? That is the most important thing. also i might add a tuner and exhaust to the truck if that makes a difference. Is there more than one tranny that dodge put in thier trucks?
post #4 of 18 (permalink) Old 03-11-2008, 11:45 PM Thread Starter
is there a significant difference in fuel mileage between auto and 5 speed/6speed?
01 dodge ram 2500 laramie ext. cab long box 4x4: 5" Turbo back exhaust edge with attitude
post #5 of 18 (permalink) Old 03-12-2008, 03:36 AM
TDG Mafia Member #45
jarhead's Avatar
this truck is going to be for business right?
if so i would go with a standard trans and a small box or a programer. you don't need to much stuff on a truck you are going to use to work with.
Randy
05 Dodge str8 pipe, smarty jr, afe, airbags, and pacbrake.
jarhead is offline
post #6 of 18 (permalink) Old 03-12-2008, 07:13 AM Thread Starter
Yes it will be for a buisness. But not everybody knows how to drive a stick, so i was looking to see if there were any advantages to a stick that would offset that. like fuel mileage. Or see if the auto was that bad to where i would be repairing it all the time. i know tha the auto in 96year trucks was pretty bad i dont know if dodge fixed it before 02 though.
post #7 of 18 (permalink) Old 03-13-2008, 01:11 AM
Torque Converter and Valve Body are what's going to be needed. And you're going to want a turner that does timing, and might as well just do the exhaust while your at it and slap on a BHAF.
auto and 5 speed :shrug: The auto has a slighty higher O/D than the sticks. However most of the 6speeds are paired with a high output engine and they seem to do a little better on fuel than the standard outputs. Check some earlier threads if you want to know the difference between the 2 engines.
The 1996 probably had a 47RE which is almost the same 47RE they put in the 2002's.
Over all I still wouldn't buy a stick for what you're doing. I'd just buy one with a blown up 47RE and beef it up. My auto is much more fun to drive than my 6speed.
Smokem is offline
post #8 of 18 (permalink) Old 03-13-2008, 01:35 AM Thread Starter
How much money to "beef up" a blown auto tranny? How long does it take? What is a BHAF?
post #9 of 18 (permalink) Old 03-14-2008, 01:54 AM
Cost depends on your torque converter and how you price it.
1000-1500$.
Valve bodys run around 400$.
A BHAF is a paper air filter out of the Marine QSB and QSC that you can use to replace your whole air filter housing:
Smokem is offline
post #10 of 18 (permalink) Old 03-14-2008, 01:55 AM
Assuming you have all the parts you need.
(Which is unlikely for most people including myself)
It'd take a person with great mechanical skill about 2-3 hours.
Normal people it'll take around 5 hours.
If I did it, it'd take all day.
Smokem is offline
