02 cummins - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by larsen02, this thread has received 7 replies and been viewed 1050 times.
post #1 of 8 (permalink) Old 04-04-2008, 05:16 AM Thread Starter
02 cummins
i currently am a new owner to an 02 quadcab longbed 2wd cummins and as wondering if anyone could tell me anything i can do to maybe increase to mileage 2-3mpg withough out spending alot of money. im not looking to make the front page of any magazines or anything, just wanting to keep alittle cash flow in my pockets as diesel prices continue to rise... thanks for your help.
larsen
larsen02 is offline
post #2 of 8 (permalink) Old 04-04-2008, 07:37 PM
The one best thing to help my fuel mileage was a bed cover. I gained one and a half miles per gallon. Other things I do is to keep the boost below 8 psi, drive no faster than 64 miles per hour. I am running synthec motor oil. Those things seam to help on mileage I have done other things that help performance.
later is offline
post #3 of 8 (permalink) Old 04-04-2008, 09:19 PM
Formerly CursedtoFirst45
StrokeThis's Avatar
a few cheap tricks are opening up your exhaust(delete muffler/cat), and getting yourself a bhaf(big honkin air filter). Both can be done relatively cheap. Filter is less than $45 i believe and the exhaust can be free if you have a sawzall. The exhaust could gain you as much as 2mpg and the filter maybe .5mpg
Eric
1994 Dodge Ram 2500
You can take our information, you can try to shut us down, but we're still here, and we're going to be better than ever!!
-John DeereGreen
StrokeThis is offline
post #4 of 8 (permalink) Old 04-08-2008, 01:18 AM Thread Starter
thanks guys
larsen02 is offline
post #5 of 8 (permalink) Old 04-08-2008, 03:21 AM
Sythetic oils, Edge Mileage Max a little over 200 bucks and get over 1MPG, if you don't 3.55 gears, get them regardless of cost. check your alignment. I'm not for sure where to stop really, but you could 30MPG if you did it right.
EDIT: Others: Shift kit, gear venders overdrive if you do alot of highway driving, I know I'm not staying in the low price range anymore but heck some alot these kind of pay for themselves.
Smokem is offline
post #6 of 8 (permalink) Old 04-08-2008, 05:06 PM
2nd Gen Guru
Mopar1973Man's Avatar
Driving slow nets the best results... On a 50 mile trip to Council, ID to get parts for a job I got back home and check my ScanGauge II and saw!
This was done by setting the cruise at 55 MPH that all... But I had to cover grades of 4,500 ft down to 2,800 ft, rolling hills and valleys...
If you want good MPG slow down it comes easy... The trick is to get your pyro under 600*F and keep your boost below 5 PSI and 20+ MPG can happen for you...:
Mopar1973Man is offline
post #7 of 8 (permalink) Old 04-10-2008, 03:08 AM Thread Starter
ive got a 3.55 rear end, and how eactly does the 2 stroke engine oil work exactly?
larsen02 is offline
post #8 of 8 (permalink) Old 04-10-2008, 04:15 AM
2nd Gen Guru
Here is my web page on it...:
http://mopar.mopar1973man.com/2002%2..._cycle_oil.htm
