02 2500 has lost its mind - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Johnnyutah, this thread has received 16 replies and been viewed 1475 times.
post #1 of 17 (permalink) Old 04-15-2008, 05:46 AM Thread Starter
Unhappy 02 2500 has lost its mind
my 2002 dodge has the crazy idle going on not the tps not injecter pump it is throwing 9 different t codes assp, ecm failer intake somthing or other charging failer to much voltage here and there i have read about the alternator cleared the codes that would clear with the smarty unhooked the alternater i even reset the tps it has a mind of its own. it fires up and the engine light stays on i have no control of the throttle it reves up on its own never dies though it may be missing but i doubt it would a any one might know whats up with this thing o and its a six speed:shrug:
Johnnyutah is offline
post #2 of 17 (permalink) Old 04-15-2008, 06:09 AM
it would help if you posted the codes you pulled and list them in the thread so we can help diagnose the problem
86 1 tonhauler is offline
post #3 of 17 (permalink) Old 04-15-2008, 02:19 PM
2nd Gen Guru
Mopar1973Man's Avatar
Sounds like a bad ground could be a issue...
But the listing of error code would be helpful...
Here is my OBDII write up...
http://mopar.mopar1973man.com/2002%2...rror_codes.htm
And the listing of codes...
http://mopar.mopar1973man.com/2002%2...or%20Codes.pdf
Mopar1973Man is offline
post #4 of 17 (permalink) Old 04-15-2008, 08:57 PM
Could be time for a New ECM too. Its really hard to say. I would check all of your grounds and connections first, but it may very well be that the computer is shot.
post #5 of 17 (permalink) Old 04-18-2008, 07:03 AM Thread Starter
re: lost dodge mind
yes 121 and ya some others so when i get home i will plug the smarty back in and post them, i appreciate all the concern makes me feel much better i am just a dumb rig welder i do have a new set up 07 3500 6.7 larime 6 auto i really love it with a classic 3d welder (its a diesel to) any ways im on a power plant shut down in Wyoming right now, so i wont make it back home until tuesday night i will submit then for sure o and i found out the dude who had it before me had stacked chips on it so :shrug:
post #6 of 17 (permalink) Old 04-25-2008, 12:46 AM Thread Starter
Lost dodge mind trouble codes;
OK sorry for the delay 14-16 hour days take alot out of a guy anyways here are the codes i pulled off of the smarty (to high voltage) . PO 238 map senser voltage to high, 563 chargeing system voltage to high, 118 Ect senser volage to high, 113 intake senser voltage to high, 123 TPS voltage to high, 606 ECM FAILER, 343 ESS voltage to high, 1286 accelerator position senser voltage to high, 1693 JTEC (smarty) cleared codes, 1475 Aux. 5 volt, voltage to high. Basicly the voltage is to high. I unhooked the alternator, unplugged the clip and the main cable, i even took the belt off like in the forum about the chargeing system with the wild freq. and back charge i am at a stand still the pumps are new other then the cold air intake the exhaust and injectors, smarty it is all stock. hope these codes help please and thank you:bow:
post #7 of 17 (permalink) Old 04-25-2008, 01:20 AM
Its Cute Aint it!!
You like that 300! You got the perkins or kubota? Im thinkin bout gettin me one. Just cant let go of my ol red face!:bow:
04 smarty beta 4.4 and mp-8 , superchip stickers on the windows. SOLD
Wifes 04.5 4x4 smarty and dr p box exhaust intake and new rubber 502-1162 as of 12-02-09 With mostly stock tranny. Suncoast converter and valve body.
Dad 08 swb 4x4 h&s 5in turbo back egr block edge hot unlock and crappy clutch
98 12v 5spd 4.10s bhaf, exhaust, fuel plate, 4k gsk, timing, pump mods, and 300s Studs, o-ringed head, 3 piece manifold and 5in KDP tabbed, 60lb springs, titanium keepers
Moms 03 6spd- intake, smarty jr!!
01 reg cab dually 4x4 5spd bhaf raptor 150 and comp box Farmboy 5in 2in steel spacers for the rear with 6 new 305s! injectors on the way!!!!!
kc04 is offline
post #8 of 17 (permalink) Old 04-25-2008, 04:19 AM Thread Starter
lincoln welder
The beauty of the classic 3 regaurdless of the year is the smooth clean arc and the ac 120,220 power for pipe welding your remote has ac power for hand tools. My welder is a 1991 classic 3d, with a Contenental diesel i believe how its spelled when i order my new classic 3d i will order the perkins they start better in the cold super quite and the 3ds have a 100% duty cycle at 300 amps mine is a 100% duty cycle 200 amps the price tag of $11,000 is something to think of, the turn around rate is well worth it.:Thumbup:
post #9 of 17 (permalink) Old 04-25-2008, 04:44 AM
Its Cute Aint it!!
Yeah i put a ac inverter on mine. It helps for now. Its been played with! It will stack metal with the best of em up hill on pipe. But im fixin to order me a 300. That ac plug makes all the diference in the world. With perkins and remote bout 11650 out the door. I dont think thats too bad. Gonna keep my other one as a backup.
kc04 is offline
post #10 of 17 (permalink) Old 04-25-2008, 01:12 PM
2nd Gen Guru
Voltage regulator is internal on the PCM...
So I know that the 12V trucks can put a old school voltage regulator on for a fix. But I've never seen it done on a 24V truck. I assume it could be done for a temporary fix...
But the ultimate way is to replace the PCM...
