53 block question - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Sabbath5.9, this thread has received 1 replies and been viewed 921 times.
post #1 of 2 (permalink) Old 05-06-2008, 02:01 AM Thread Starter
Upside Swordfish
Sabbath5.9's Avatar
53 block question
Ok so i've been searching for about a hour on stuff about 53 block... and my question is.. is there a certain year the 53 block is in the truck?? or the vin number??
Jeff
1996 ram 2500 ex cab long 2wd, 5'' straight, 215s, 4k gsk(only revin till 3k), 16* timing, fuel plate MIA, afc modded FF, CFM intake mani, afe stage 2
15.40 at 90.61 in the 1/4th (09-18-10)
Sabbath5.9 is offline
post #2 of 2 (permalink) Old 05-06-2008, 05:42 AM
As far as what years, they were as early as 97 and as late as 01 I believe. There is no vin code or specific year that they were in either. You will have to actually get out and look at the block to find out for sure. To add to that, a guy out here recently had the same cracking problem occur on his 55block, in the same place that it does on the 53block. There is a really good sticky at the top of the forum about 53blocks. Not all of them crack, and it has nothing to do with the amount of power either. I personally haven't seen very many of them. And none that had cracked.
