Loud or louder nocking noise - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by XSIVPWR, this thread has received 14 replies and been viewed 1927 times.
post #1 of 15 (permalink) Old 01-07-2009, 05:29 AM Thread Starter
I have a 01 24vho 6speed I just came back from a trip and now I have a loud or louder nocking noise in the motor. I am pretty sure it's not bottom end, oil pressure is normal temp is normal run as good as ever no power loss no codes. Hell maybe I'm crazy. I thought maybe the injector pump because it sounds high up in the motor but I would think it would set a code unless their is no pressure drop. Any ideas? Thanks.
XSIVPWR is offline
post #2 of 15 (permalink) Old 01-07-2009, 06:23 AM
TDG Mafia #86
lilrebeljames's Avatar
my 05 is nocking now if my motor is cold it dont do it
2005 dodge 2500 2x4 q/c 6-speed,
5 inch mbrp muffler with two 7inch stacks , silencer ring gone SMARTY06,AIRDOG FP150, south bend 1947 con fe ,AIRAID Intake ,cat gone
lilrebeljames is offline
post #3 of 15 (permalink) Old 01-07-2009, 03:16 PM
Its sounds like an injector nock to me Do you see any white somke
2005 3.9 Cummins 4BTAA 94 dodge 1500 2wd A518 trans 27 mpg around town
http://www.cumminsforum.com/forum/cu...ics-truck.html
Friends 95 dodge 2500 #6 fuel plate and 35lbs of boost.
JakeDiesel is offline
post #4 of 15 (permalink) Old 01-07-2009, 04:06 PM Thread Starter
No. That's the strange thing, the noise is there but nothing about the truck or the way it run's has changed.
Thanks for the reply.
XSIVPWR is offline
post #5 of 15 (permalink) Old 01-08-2009, 12:10 AM
Have the valves checked just to be on the safe side, if its worth it to ya pop the valvecover off anyways and see if you can narrow the noise down better, you shouldn't really need to have the valves adjusted unless you have well over 100,000 miles, have them checkes anyways.
cumminsdude2001 is offline
post #6 of 15 (permalink) Old 01-08-2009, 02:49 AM Thread Starter
It doesn't sound like valves but you never know, I'll look in to that. It has 117000 mi on it. It sounds like your hitting a anvill <spelling) with a hammer. If I had to guess the noise has allways been there it is just louder like something is wearing out.
Thanks.
XSIVPWR is offline
post #7 of 15 (permalink) Old 01-08-2009, 04:09 AM
Of Course
Trunion, valve bridge, or dropped seat.
That Guy is offline
post #8 of 15 (permalink) Old 01-08-2009, 04:56 AM Thread Starter
If it was any of these things would it still run normal?
XSIVPWR is offline
post #9 of 15 (permalink) Old 01-08-2009, 05:31 AM
Of Course
If a bridge was broken it would be noticeable in performance, a failed trunion or dropped seat would not. From the description I would say a valve seat came unseated.
That Guy is offline
post #10 of 15 (permalink) Old 01-08-2009, 04:07 PM Thread Starter
how would I go about checking them? Thanks.
XSIVPWR is offline
Loud Drone noise and vibration Stouttrout 2003-2007 6.0L Power Stroke 7 01-06-2008 11:37 PM
loud noise at idle ?? 96sierraz71 1994-2003 7.3L Power Stroke 4 12-01-2007 03:45 AM
I have a 2001 Dodge Deisel Dually and now I have a loud humming noise marlena4syth 5.9L Cummins (1998.5-2002) 1 07-30-2007 10:50 PM
loud front end noise dozer8 5.9L Cummins (2003-2007.5) 7 02-19-2007 05:07 PM
Loud vibration and noise BriteWhiteRam 5.9L Cummins (2003-2007.5) 9 12-21-2006 02:34 AM
