Bad injectors? Bad turbo??? - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by NCcummins, this thread has received 20 replies and been viewed 1733 times.
post #1 of 21 (permalink) Old 01-09-2009, 03:26 AM Thread Starter
NCcummins's Avatar
Angry Bad injectors? Bad turbo???
Alright well I have no idea what is going on with the truck. If I let of the gas and then press it back down, I can put it all the way to the floor, no smoke at all, and no turbo boost building then all of a sudden its like someone clicked a switch and it builds boost right away. I can hear the turbo whistling but I am sure that is just because the truck is gaining speed. At a stop sign, I can put it all the way to the floor, and it hardly moves and jolts back and forth a little bit. Sometimes it takes me 4 or 5 times pressing it to the floor, letting off, and doing it again to get it to build boost at all!!!!
There is no white smoke at all so I am guessing it would not be injectors?
Any help is great! IT JUST STARTED DOING THIS tonight right after I filled up with a tank of fuel. Maybe its the diesel fuel? I am not sure
2002 WRX
NCcummins is offline
post #2 of 21 (permalink) Old 01-09-2009, 04:12 AM
Official TDG Doctor
hccumminssmoke's Avatar
have you checked for a MAJOR leak? shaft play? hows oil pressure? any knocking? is it all black smoke? any blue?
Nate
hccumminssmoke is offline
post #3 of 21 (permalink) Old 01-09-2009, 01:06 PM
WHOS NEXT
it almost sounds like you got bad fuel which is bad news. it is most likely is taking out you injection pump and possibly your injectors and lift pump
smokin24valve is offline
post #4 of 21 (permalink) Old 01-09-2009, 01:45 PM
What are sparkplugs
ICEMAN3005's Avatar
mostly likely a bad apps or Injection pump or both. My truck did same thing lasted about 1 year like that before it died
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #5 of 21 (permalink) Old 01-09-2009, 02:16 PM Thread Starter
NCcummins's Avatar
just replaced the injection pump maybe 5 months ago....bad fuel would suck! I am leaning towards a APPS hopefully...
it blows all black smoke if it blows any at all..no knocking at all and oil pressure is great..
2002 WRX
post #6 of 21 (permalink) Old 01-09-2009, 02:22 PM
Taylor34's Avatar
Bad fuel doesnt always suck as long as you have your receipt we had a few years ago the town gas stations diesel tank got a crack in it and ground water leaked it it screwed up three trucks and they still had there receipts and they paid with credit card so they got it traced back to that station cuz it was the last place they filled up and i know one guy got everything from a new tank to new injectors and everything in between it ended up being around a $7500 insurance claim for the gas station...needless to say we drive 10 miles now to fill up
2008 Ford F150 SuperCrew FX4, Leather, 20" Roush Rims, Audiophile Sound System, Sunroof, Edge Evolution
"SOLD" 2001 Dodge 2500 Quad Cab Long Box CTD, Edge Juice w/Attitude, Airdog 150, BHAF, Silencer Ring Removed, 4in. Straight Pipe w/6in tip, 2in. Leveling Kit, Phase Linear Dvd Player, Linex Bedliner-Rocker Panels-Hood, B&W Gooseneck Hitch
TDG Ridin' Dirty #16
TDG B.O.M.B Squad #16
Taylor34 is offline
post #7 of 21 (permalink) Old 01-09-2009, 02:25 PM Thread Starter
NCcummins's Avatar
dang! well i have my receipt because it was on a credit card so if it is bad fuel, I know which shell station I will be going to!
2002 WRX
post #8 of 21 (permalink) Old 01-09-2009, 02:41 PM
stillcrazyinlaw's Avatar
Images: 3
It does sound like bad fuel, I got a tank full in my 12 valve about 6 years ago and did very similar things. I didn't have a reciept and bought a new lift pump and rebuit inj pump and new injectors all on my dime.:
Drain the tank and hope for the best.
yulan
stillcrazyinlaw is offline
post #9 of 21 (permalink) Old 01-09-2009, 02:42 PM
Taylor34's Avatar
nc i would go there today and tell them what has been goin on so they have some kind of idea whats happening so you just dont pop in one day and tell them and then theyd think your just trying to pull a quick one on them
Taylor34 is offline
post #10 of 21 (permalink) Old 01-09-2009, 07:52 PM
99 cummins
customdeluxe78's Avatar
good advice taylor34, its also possible other people have had problems and came back too. but the chances of them telling you that might not be too good. what im saying is if more than one person has said something then they will know there is a problem with the fuel.
99 cummins, 5-speed, edge comp, speedhut guages, fass 150 system, s&b cold air intake, ces two piece manifold, 5 inch straight exhaust with a 6 inch tip, 5 inch superlift, 4:10 gears, dynatrack lock in lock outs, 35x14.50 thornbirds on 16.5x12 mickey tompson classic 2's, alpine head unit, 1600 watt amp, 2 12 inch subs
customdeluxe78 is offline
Turbo and Injectors drummerboydw Whats Been Sold 0 03-01-2008 01:13 AM
New turbo & injectors skipped_link Whats Been Sold 9 12-16-2007 12:15 PM
7.3 turbo and injectors lukecline Whats Been Sold 2 12-10-2007 06:02 PM
Turbo and Injectors? Big Bad Stroker 1994-2003 7.3L Power Stroke 6 03-02-2007 03:51 AM
Turbo / injectors ?'s firedawg General Ford Truck and Excursion 27 01-13-2007 10:08 PM
