Boost - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by JLWelding, this thread has received 4 replies and been viewed 810 times.
post #1 of 5 (permalink) Old 01-10-2009, 11:37 PM Thread Starter
JLWelding's Avatar
Boost
With everything my truck has I can only build 30lbs of pressure is this normal.Before 75hp inj. 29lbs
JLWelding is offline
post #2 of 5 (permalink) Old 01-11-2009, 01:25 AM
2nd Gen Guru
Mopar1973Man's Avatar
What kind of boost elbow do you have? Is the type with the little set screw or not? If its adjustable you can screw it in a little at a time and gain more boost. But don't want to exceed 35 PSI that's max for the stock turbo...
If you got a non-adjustable you going to hve to change it got get more...
You could take a pair of vise grips and clamp the rubber hose off and see if the boost will climb more...(This is for HX35 Turbos)
Mopar1973Man is offline
post #3 of 5 (permalink) Old 01-11-2009, 02:47 AM
Official TDG Doctor
hccumminssmoke's Avatar
He can exceed 35lbs it just doesnt help blow hot air back...
Nate
hccumminssmoke is offline
post #4 of 5 (permalink) Old 01-11-2009, 03:20 AM Thread Starter
JLWelding's Avatar
You could take a pair of vise grips and clamp the rubber hose off and see if the boost will climb more...(This is for HX35 Turbos)[/QUOTE]
It is the elbow that Edge sends with the Ez. No screw. I just thought it would be higher than that. Where would you find the elbow with screw?
post #5 of 5 (permalink) Old 01-11-2009, 03:39 AM
Official TDG Doctor
It is the elbow that Edge sends with the Ez. No screw. I just thought it would be higher than that. Where would you find the elbow with screw?[/QUOTE]
Here ya go:
http://www.xtremediesel.com/bd-power...ce1040310.aspx
http://www.tstproducts.com/tstboostcontrol.aspx
I a TST one lying around somewhere i'll letcha know if i find it with in a couple of days...
Nate
Raising Boost, Meth Injection, Boost controllers, etc.... Stinger23 1994-2003 7.3L Power Stroke 14 04-15-2008 09:35 PM
Turbo Boost No Boost Burner718 1994-2003 7.3L Power Stroke 16 04-02-2008 04:14 AM
Boost and what should it be? Spicewood 6.5L Diesel Engine 9 03-02-2008 04:47 PM
more boost? 05dury 5.9L Cummins 12 Valve (1994-1998.5) 28 11-30-2007 11:27 PM
too much boost! dangerous196 5.9L Cummins 12 Valve (1994-1998.5) 9 06-11-2007 03:00 AM
