high idle - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by 01quadcab, this thread has received 6 replies and been viewed 1135 times.
post #1 of 7 (permalink) Old 01-12-2009, 04:54 PM Thread Starter
high idle
called doge today to get a price on a reflash and getting the high idle for my 01.. he stated it's not available for an auto. So I went to mopar mans site and
TSB 18-019-01 - Cold Idle Engine Warming
Date: September 3, 2001
Models: 1998 1/2-2002 BR/BE Ram Trucks
NOTE: THIS BULLETIN APPLIES TO ALL RAM TRUCKS BUILT AFTER DECEMBER 17,1997 AND EQUIPPED WITH THE 24-VALVE 5.9L CUMMINS DIESEL ENGINE"
so what do I tell the dealer? I need a reflash due to possibly having a superchip stored in the computer. My edge on 6 does not work think it's over timing the vp and thats not good
01quadcab is offline
post #2 of 7 (permalink) Old 01-12-2009, 05:07 PM
Official TDG Doctor
hccumminssmoke's Avatar
Tell them that you have re programmed the ECM with an aftermarket tuner and that you want to return to stock settings...and if the say thats not possible tell them to go get re educated...not really but try to call another dodge dealer...
Nate
hccumminssmoke is offline
post #3 of 7 (permalink) Old 01-12-2009, 05:14 PM Thread Starter
they can do the reflash but it wont have the high idle.
post #4 of 7 (permalink) Old 01-12-2009, 05:26 PM
Official TDG Doctor
then re flash and tell them to activate high idle or find someone with a SMARTY...
Nate
The Following User Says Thank You to hccumminssmoke For this addition to TDG:
01quadcab (01-12-2009)
post #5 of 7 (permalink) Old 01-12-2009, 07:08 PM Thread Starter
well I found a auto shop that can reflash and save me 10bucks so gonna do that and see if they have the option or like you say find a smarty. Thanks for the help
post #6 of 7 (permalink) Old 01-13-2009, 01:27 AM
2nd Gen Guru
Mopar1973Man's Avatar
Print out the TSB and take it with you to the Dodge Dealer and have them set appointment. Because it only a few steps...
7. Connect the DRB III to the vehicle without connecting to MDS2 and follow the menu structures it appears below.
8. MAIN MENU - 1998 - 2002 DIAGNOSTICS
9. 1998 - 2002 DIAGNOSTICS - ALL (EXCEPT BELOW)
10. SELECT SYSTEM - 1 ENGINE
11. CONTROLLER TYPE - 1 CUMMINS (ECM/ENGINE)
12. SELECT FUNCTION - 1 MISCELLANEOUS (Misc. is on second page)
13. 3.3 CYLINDER IDLE - Follow the instructions
The DRB III will indicate whether the feature is enabled or disabled.
14. Push 1 to Enable, 2 to Disable.
15. You are instructed to cycle the ignition to complete the repair.
16. Press Page Back to Exit.
They don't need to flash nothing that just got to ENABLE the software! :
Like I said before and I'll say it again... If you can program it with a Smarty in less than 2 minutes why would a Dodge dealer need to flash anything??? If you need to read the directions to the tech...
Mopar1973Man is offline
post #7 of 7 (permalink) Old 01-13-2009, 05:48 AM Thread Starter
thanks. I was just trying to get this while I was getting computer set back to stock
Skweeker Mod (High Idle or Aux. Idle) CBSuperduty Ford - Modification instructions, Product installs and Tech Articles 23 12-31-2009 03:22 AM
High Idle & High Idle Kicker... Mopar1973Man 5.9L Cummins (1998.5-2002) 4 12-25-2008 01:36 PM
High Idle Mod On Lmm? FX4DUDE Duramax 07.5-2010 (LMM) 2 11-03-2007 11:15 PM
High Idle & 3 Cylinder Idle Mopar1973Man 5.9L Cummins (1998.5-2002) 11 11-02-2007 01:44 AM
High Idle ?'s One Fast Harley 2003-2007 6.0L Power Stroke 4 09-18-2007 12:01 AM
