Cruise Control - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Imbiggerthanyou, this thread has received 9 replies and been viewed 1419 times.
post #1 of 10 (permalink) Old 01-15-2009, 01:47 AM Thread Starter
Cruise Control
When I put the cruise control on the truck surges real bad with the edge attitude and when it is off it cant hold speed on a hill
02 Dodge 3500: Auto tranny, BHAF, Auto Meter Cobalt gauges, 4" exhaust, and most importantly heated leather seats because Alaska is cold. :givemebeer
Imbiggerthanyou is offline
post #2 of 10 (permalink) Old 01-15-2009, 12:35 PM
payne86's Avatar
hmmm..... well mine does the exact thing, i dont even use my cruise cause it surges so bad.
2006 Chevy Duramax LBZ 4x4 2500 Regular Cab. 5inch exhaust,everything else is Bone Stock for now............................... SOLD......2001 Dodge 2500 4x4 Regular Cab Cummins. Ats intake horn,Ats Exhaust Manifold, AFE stage II intake, Edge Comp, Superchip,FASS 95,Luk clutch(450),boost elbow,5in turbo back stait piped. silincer ring lost, 2in levelingkit 305/70/16 on 16-10.
payne86 is offline
post #3 of 10 (permalink) Old 01-15-2009, 02:16 PM
2nd Gen Guru
Mopar1973Man's Avatar
That's really odd... The 2002 Dodge is completely electronic on the cruise control.
So try a test and disconnect the Edge completely from your truck and see if it will hold a hill and behave correctly. If it does then the Edge is the problem and should be set back for repair.
I've got a Edge Comp leave it on 5x5 and set my cruise for 65 MPH for over 2.5 hours yesterday and no surge, no problems...
Mopar1973Man is offline
post #4 of 10 (permalink) Old 01-19-2009, 01:49 PM
What are sparkplugs
ICEMAN3005's Avatar
mine also surges but I think its my hotrod pump that causes that, when I just had the edge no other mods mine didn't surge on level 5
2002 dodge 2500 4x4
Edge Juice W/Attitude
Hot Rod VP-44 stage 2
200 H.P. Injectors
HX-40 turbo(Silencer Ring MIA)/ BHAF
FASS 150/150
billet trans/TC 1600 stall (rebuilt myself) parts supplied by DUNERITETORQUECONVERTERS
2" leveling front kit
TRUCK SOLD
Two 84 chevy 1 1/2 ton pickups 6.2L Diesel (stock)
Turbo400, NP208 transfer case, Dana 60 front, GM 14 bolt rear W/Locker
89 Chevy K-5 Blazer 350/700r4/np241/gm10bolt rear dana44 front
ICEMAN3005 is offline
post #5 of 10 (permalink) Old 01-19-2009, 11:32 PM Thread Starter
I took it off and it wont hold a hill at 65, it has to down shift. It surges in all the levels.
post #6 of 10 (permalink) Old 01-19-2009, 11:52 PM
What are sparkplugs
ICEMAN3005's Avatar
sounds like your having an electrical problem than could be speed sensor is going bad or APPS not sure
2002 dodge 2500 4x4
200 H.P. Injectors
FASS 150/150
TRUCK SOLD
post #7 of 10 (permalink) Old 01-20-2009, 07:24 PM Thread Starter
APPS is brand new. I'm going to check the speed sensor.
post #8 of 10 (permalink) Old 01-21-2009, 04:03 PM
cowboytw13's Avatar
Have you checked the codes. I know an APPS would throw a code, but I'm not sure about the speed sensor.
cowboytw13 is offline
post #9 of 10 (permalink) Old 01-21-2009, 11:04 PM
What are sparkplugs
ICEMAN3005's Avatar
code P 0500 through P0503 would be speed sensor
2002 dodge 2500 4x4
200 H.P. Injectors
FASS 150/150
TRUCK SOLD
post #10 of 10 (permalink) Old 01-24-2009, 02:01 PM
2nd Gen Guru
On a 2002 ECM & PCM controls the speed during cruise control... The APPS is not used. It got to be a electrical problem...
cruise control topflight250 1994-2003 7.3L Power Stroke 9 01-15-2009 11:09 PM
Cruise Control CBF 2003-2007 6.0L Power Stroke 7 03-18-2008 04:43 PM
Cruise Control vs. MPG volwing 2008-2010 6.4L Power Stroke 4 02-23-2008 11:22 PM
Cruise Control???? DeezelDog 5.9L Cummins (1998.5-2002) 6 02-28-2006 10:32 PM
cruise control tjl 1994-2003 7.3L Power Stroke 9 07-09-2005 09:58 AM
