Gelled fuel/ Damage to IP- NEED HELP!!! - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by dannyboy403, this thread has received 7 replies and been viewed 1353 times.
post #1 of 8 (permalink) Old 01-16-2009, 11:19 PM Thread Starter
OK the truck is a 2002 24v. Here is the problem I went out this morning to start it waited for the light to turn off fired right up (the that's a cummins for ya!) fuel pressure was good (14 psi At idle) let it warm up for about 10 min. Took off down the road an taking it easy and the fuel pressure started to drop it was at 5 psi at 1500 rpm so i knew something was not right so i turned around and headed back to the house and 1/4 mile from the house it went to 0 psi and started to sound like it was missing. so i got it home and went to shut it off and it idled fine. i just put an new injection pump on 9 months ago and im hoping i did mess this one up cause i don't want to do it again. it was -33 degrees last night so i think the fuel turned to gel. the main question is do you think i did damage to the pump and is there a way for me to check it???????
dannyboy403 is offline
post #2 of 8 (permalink) Old 01-16-2009, 11:33 PM
JLWelding's Avatar
Going by what I was told,it should not hurt it if you are running 2 stroke oil. I was running out of fuel (sendor out) and it got down to zero and stayed there about 5 seconds at a time did this about 4 times before I was able to fuel up. So far so good. Hope this is some help or relief.
JLWelding is offline
post #3 of 8 (permalink) Old 01-17-2009, 12:27 AM
Taylor34's Avatar
same thing happened to mine i took it to the dealer it was there idling for 10 minutes and the psi came back they said that if the fuel is a little jelly it will stick to the sensor and coat it so it doesnt read the psi but its still pumping just fine
2008 Ford F150 SuperCrew FX4, Leather, 20" Roush Rims, Audiophile Sound System, Sunroof, Edge Evolution
"SOLD" 2001 Dodge 2500 Quad Cab Long Box CTD, Edge Juice w/Attitude, Airdog 150, BHAF, Silencer Ring Removed, 4in. Straight Pipe w/6in tip, 2in. Leveling Kit, Phase Linear Dvd Player, Linex Bedliner-Rocker Panels-Hood, B&W Gooseneck Hitch
TDG Ridin' Dirty #16
TDG B.O.M.B Squad #16
Taylor34 is offline
post #4 of 8 (permalink) Old 01-17-2009, 12:51 AM
get yourself some cold flow improver, or something for gel point reduction and change your filters. You should be ok.. what lift pump you running? Or start running 2 stroke oil
01quadcab is offline
post #5 of 8 (permalink) Old 01-17-2009, 02:23 AM Thread Starter
I had Power Service in it and 2 stroke i dont know what happend. i an running a FASS 150
post #6 of 8 (permalink) Old 01-17-2009, 04:03 PM
2nd Gen Guru
Mopar1973Man's Avatar
Check for error codes...
(But I know you already seen the post elsewhere! )
But The PowerService rank low in lubricity I would suggest a better fuel additive than PS...
Mopar1973Man is offline
The Following User Says Thank You to Mopar1973Man For this addition to TDG:
todt061458 (01-20-2009)
post #7 of 8 (permalink) Old 01-17-2009, 05:31 PM Thread Starter
Do i also have to replace the FASS filters too or can i just thaw them???
post #8 of 8 (permalink) Old 01-18-2009, 12:55 AM
2nd Gen Guru
You can thaw them out...
Can a CPS failure cause damage to motor ??? NORCAL-NOODLER 1994-2003 7.3L Power Stroke 6 12-20-2007 02:16 AM
How much damage did I do to my tranny? Cerebus 1994-2003 7.3L Power Stroke 10 06-02-2007 01:55 AM
Tornado damage in Greensburg,KS Squatch The Parking Lot 14 05-10-2007 04:28 AM
Damage done to Chrysler may be irreversible BROKER The Parking Lot 0 04-13-2007 02:44 AM
Bad Hail Damage In Exeter Nh BROKER The Parking Lot 9 07-12-2006 08:37 PM
