Clutch Hydraulics... - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by Mopar1973Man, this thread has received 6 replies and been viewed 964 times.
post #1 of 7 (permalink) Old 01-17-2009, 03:04 PM Thread Starter
2nd Gen Guru
Mopar1973Man's Avatar
My clutch hydraulics system is start to fail... I was starting at a traffic light and just holding my clutch down and the brake as typical.
The ruck started to push forward against the brake and grunt. I reached for the stick to pull it out of gear and it was bound up under tension. So I shut down the engine and pull it out of gear. So every time I come to a stop now I make sure I'm neutral.
But now I've heard stories about the hydraulic system that its a PITA to deal with. Can someone with experience guide me to proper replacement so I'm not pulling my hair out...
(Yes... Mopar1973Man is a on the learning curve again!)
Mopar1973Man is offline
post #2 of 7 (permalink) Old 01-17-2009, 06:10 PM
stock is boring
Both valair and sb have preassembled upgrade kits available they both are direct replacement and are easy to install. Check with some of the vendors, I do know that DPPI carries SB product
'04 LB7 4DR LONG BED 4x4
'02 LB7 REG CAB Utility body 2wd
dragnsled is offline
post #3 of 7 (permalink) Old 01-24-2009, 09:29 PM Thread Starter
2nd Gen Guru
YEAH! I got it done the first time! No air in the system and did it just about 2 hours!
There will be a write posted soon... You cannot believe how easy it was to do!
Old System
New System - While bleeding
post #4 of 7 (permalink) Old 01-27-2009, 12:48 AM
lbdodge24v's Avatar
A good write up on that will be good, I am thinking I am headed down that road soon myself.
02 Dodge Ram CTD, 6 spd., HMR Street Drag Clutch, Raptor 150, Edge Drag Comp, Smarty, Injectors, aFe air intake, 2 in leveling kit, 4 in exhaust, and 3 guages-Fuel Pressure, Boost, and EGT's.
The Toy a Jummins!!
lbdodge24v is offline
post #5 of 7 (permalink) Old 01-27-2009, 03:00 AM
Agreed^
Carbur8tr is offline
post #6 of 7 (permalink) Old 01-27-2009, 01:11 PM Thread Starter
2nd Gen Guru
So far I've got 150 miles on it and it acts just like stock clutch the day I bought the truck of the showroom floor in Oct 2002!
So all the rumors of DON'T but the NAPA clutch master/slave cylinder are all false and it can be done so easy and cheap...
Sorry Dodge Dealers you loss another source of income!
Here is the write up...
http://mopar.mopar1973man.com/tips/c...tch%20-Hyd.htm
post #7 of 7 (permalink) Old 01-27-2009, 01:41 PM
How about a sticky for this, and Dual K20's AFC write up?
later is offline
Upgraded Clutch Fork w/South Bend Clutch??? Stinger23 1994-2003 7.3L Power Stroke 5 09-07-2010 10:50 PM
kubota hydraulics rockntractor Utility & Farm Tractors 5 01-16-2009 01:30 AM
Upgrade Hydraulics for 3rd gen G56 Dodge ASAP catdude Supporting Vendors Forum 0 12-23-2007 03:17 PM
South Bend Hydraulics Dual K20s 5.9L Cummins 12 Valve (1994-1998.5) 1 08-12-2007 09:23 PM
Live Hydraulics on 6.0? VMAC Air? Birken Vogt Medium and Heavy Duty 5 04-15-2007 03:40 AM
