No power steering or power brakes - Diesel Truck Forum - TheDieselGarage.com
Thread Details Posted by bigdaddy1, this thread has received 7 replies and been viewed 15802 times.
post #1 of 8 (permalink) Old 01-21-2009, 02:29 AM Thread Starter
I have a 2001 cummins 24 valve . Yesterday I started it and it had no power brakes or steering. I pulled off a vacume line and had some pressure. does any body know what the pressure should be or what else might be the problem?
bigdaddy1 is offline
post #2 of 8 (permalink) Old 01-21-2009, 03:10 AM
Taylor34's Avatar
was it really cold out bc mine does the same thing when its cold and then if you let it warm up a bit it will come back
2008 Ford F150 SuperCrew FX4, Leather, 20" Roush Rims, Audiophile Sound System, Sunroof, Edge Evolution
"SOLD" 2001 Dodge 2500 Quad Cab Long Box CTD, Edge Juice w/Attitude, Airdog 150, BHAF, Silencer Ring Removed, 4in. Straight Pipe w/6in tip, 2in. Leveling Kit, Phase Linear Dvd Player, Linex Bedliner-Rocker Panels-Hood, B&W Gooseneck Hitch
TDG Ridin' Dirty #16
TDG B.O.M.B Squad #16
Taylor34 is offline
post #3 of 8 (permalink) Old 01-22-2009, 12:57 AM
You shouldn't be worried about vacum. Dodge brakes are hydro-boost. Runs off the power steering system. I did switch my power steering fluid to redline synthetic and that made it more responcive. If you have a plow for the truck, it don't matter. I could never figure out why the power steering system has a hard time working with the plow on at a stand still, makes me wonder if the power steering pumps aren't powerful enough.
cumminsdude2001 is offline
post #4 of 8 (permalink) Old 01-22-2009, 02:00 PM
2nd Gen Guru
Mopar1973Man's Avatar
How you PS fluid look is it clear and light clear or does it look like used motor oil???
I never have a problem with mine because the sole fact is that system has no filter and the fluid NEEDS to be changed at 30K miles. The fluid is also used as a lubricant. So after the fluid start breaks down (darken in color) then debris start flowing then it start damaging everything in the system (or plug it up).
I'm about due for a PS fluid change so when I get ready to do it I'll do a full right up on it!
Mopar1973Man is offline
post #5 of 8 (permalink) Old 01-24-2009, 04:09 AM
You should do a write up on that when you decide to, cause I need to do mine as well.
Carbur8tr is offline
post #6 of 8 (permalink) Old 01-24-2009, 04:43 AM
I did the amsoil synthetic power steering to mine a month ago and it didn't have the cold issues like it did winters past and make a weird noise till warm. I had one break in my dads truck and that sucks when you have no brakes or power steering and are out fishing in the backwoods
01quadcab is offline
post #7 of 8 (permalink) Old 01-24-2009, 01:56 PM
2nd Gen Guru
Neither do I... But I'm using plain ol' SuperTech Power Steering fluid. It get changed ever year basically... Like right now I'm coming closed to due date on the PS fluid and it now just barely start to whine on cold mornings... Soon as I flush it out and change it I will stop like usual...
I know exactly what you mean...
Try driving a 40K# water tender without power steering...
post #8 of 8 (permalink) Old 01-24-2009, 04:53 PM
sounds like fun. but you did have good brakes I bet.. 35's are a pain in the mud to turn with out it.
Lost Power Steering and Brakes Red Power 6.5L Diesel Engine 3 02-20-2008 12:24 AM
no power steering/brakes help? Dodge-Power 5.9L Cummins 12 Valve (1994-1998.5) 8 12-09-2007 07:56 PM
Lack of Power Brakes!!! imported_Stroker01 1994-2003 7.3L Power Stroke 5 10-01-2007 12:31 AM
power steering/brakes 2000cummins 5.9L Cummins (1998.5-2002) 1 08-14-2007 10:50 PM
no power brakes just visiting 1994-2003 7.3L Power Stroke 6 03-28-2007 04:59 PM
